Like Tree3Likes
Xray T1
Old 08-09-2004, 11:04 AM
  #8386
theisgroup's Avatar
funny, I have been to that warehouse I think. And it could not happen to a nicer guy. I met Ralph and he is a great guy to talk to. And he runs at the local carpet track from time to time.
He also pits in the room just next to ours. Soo cool for me
www.xray-usa.com
theisgroup is offline
Old 08-09-2004, 04:25 PM
  #8387
berger's Avatar
Had a cracking weekends racing with my xray, finished 6th in the A on saturday after breaking it near the end of the final. And 2nd in the A main on a cooler sunday with light rain half way through the race, which made the surface "interesting" in practice i broke a few bits and pieces but i was wondering is there a technique to removing the dogbones and bearings from broken steering blocks, i have tried tapping it with a hammer but it just wont budge.
berger is offline
Old 08-09-2004, 05:12 PM
  #8388
etzkev's Avatar
Thats why you should have gotten the Spring Steel Hubs. Those dont expand, which pinches the bearings, making it nearly impossible to get them out with out damaging them.
-Kevin
etzkev is offline
Old 08-09-2004, 05:33 PM
  #8389
theisgroup's Avatar
get a very small file and file down the duraluminum axel until they come out of the sterring knuckle. make sure not to use too much force when taping, you will destroy the bearing race if too much pressure.
Old 08-09-2004, 05:49 PM
  #8390
Neil Rabara's Avatar
Get the spring steel axles. Throw away the broken units.
Neil Rabara is offline
Old 08-09-2004, 05:51 PM
  #8391
JohnMatrix's Avatar
do we have part numbers on the steel one?
thanks
JohnMatrix is offline
Old 08-09-2004, 06:02 PM
  #8392
Here you go:
http://www.teamxray.com/teamxray/pro...&kategoria=528
Old 08-09-2004, 06:08 PM
  #8393
JohnMatrix's Avatar
Thanks Neil,
Now these are for front and back or just back?
thanks again.
Nick
Old 08-09-2004, 06:09 PM
  #8394
Originally posted by JohnMatrix
Thanks Neil,
thanks again.
Nick
You use the larger rear hubs in the front c-hub. If you are using the PB suspension, then use the smaller hubs.
Old 08-09-2004, 07:43 PM
  #8395
Regional Moderator
BHenderson's Avatar
Default Anyone had this happen? howd ya fix it?
I have the spring steel hubs in the front of my car and have a small problem.
I usually run CS premounts and I have a bunch of the old spoke style as well as some of the new bbs style wheels. I have the proper screws and the small bevel washers to fix inside the smaller opening in those wheels. That being said here's my problem, no matter how hard I turn the screw, trust me its on there when i put it on he track, sometimes either one of the front wheels will go flying off during a race. Has anyone else had this happen to them? It has happened to me 4-5 times this year that I know of in the A main and happened this past Sunday. There is nothing worse than knowing you have a decent car out there only to watch a wheel go flying off your car to end your race. Any REAL suggestions on how to fix this problem?
BHenderson is offline
Old 08-09-2004, 07:51 PM
  #8396
I would try using thread lock. I have had the wheel fly off but it's been because I forgot to tighten just before the race.
g_bruin is offline
Old 08-09-2004, 07:54 PM
  #8397
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
are you putting the concave washers on the correct way?
dontfeelcold is offline
Old 08-09-2004, 07:55 PM
  #8398
Regional Moderator
BHenderson's Avatar
I have thought about that but I didnt know if I should buy another set of spring steel hubs, thought maybe mine are wallowed out or something
Old 08-09-2004, 07:57 PM
  #8399
Regional Moderator
BHenderson's Avatar
Yea, I have 10 sets of the small mount screwsets. I put new ones on every 4th race or so....when i notice the washers start to flatten out.
Old 08-09-2004, 08:00 PM
  #8400
ive never had my wheels come off except for when i didnt use the washers, and the washers i use are ancient, some of them a couple of years old from an Evo2. crank the screws up some more. or get someone else to do it
