XRAY T3
Old 01-07-2010, 04:41 AM
  #1321
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Originally Posted by hanulec
I know that both Rui and I have been moving closer and closer to Drew Ellis' setup
http://forum.teamxray.com/xform/inde...=1172&setup=t3
it looks like Drew just updated his setup today. he wasn't running the rear arm mounts at +0.75 previously.... and he was running a lower rear camber link at position #1 instead of #3.
to keep the car from rolling i'd suggest using the low (-.75) roll center front arm mounts, along w/ adding 0.75 mm spaces to shim the arm out to 2.25mm from the front bulkhead. this will put the car at the maximum legal 190mm width.
Here is my current setup. Its a good starting point for any HIGH grip carpet track. http://forum.teamxray.com/xform/inde...=1174&setup=t3
I have a few setting like Drew did but not much.
nitrobeast is offline
Old 01-07-2010, 04:50 AM
  #1322
nitrobeast's Avatar
Originally Posted by Joey4875
Well I got the car when the first batch came out and tonight was the night the screw finally ripped through my chassis. I put CA everywhere that didn't do S. I will post pictures in a few.
That sucks...I dont see how people are having problems. We have a couple at our track and seen a few bad blowouts and they keep running. I ran mine for 4 weeks without a problem and this weekend put in the 1 piece and everything is still good. The one thing i made sure of was that the screws were always tight. After 2-3 runs i always cranked on them.
Old 01-07-2010, 07:15 AM
  #1323
Default Anyone running foam?
I have to ask, as I only see one foam setup on the xray website and in the area we still run foam and not rubber.
2010 US spec that is very ill handling. Car is running the kit setup, and cannot get the car to have the 12 scale like handling I am used to. My T2 2008 was perfect on the kit setup but, this one is not even close on the kit setup. The car pushs then hooks, both directions sometimes traction rolling. I have tried thicker oil, increased toe, decreased droop in the front, Decreased toe in the on the back. Running double pink jaco all around at 56 mm with a standard neutral Stratus Body. Checked to make sure nothing is bent or dragging in the suspension. The general the car doesnt respond, feels very dead and tippy when on track, reguardless of traction.
Since I dont really get a chance to practice much, I am looking for some suggestions on what to try next as I am at a loss.
Thanks,
simulatedwood is offline
Old 01-07-2010, 05:00 PM
  #1324
xray2050's Avatar
Trader Rating: 15 (100%+)
I agree there is not much online for T3 foam set-up but I found that the kit set-up is a good start. Not sure how you got it to push? Out of the box it steered like nothing I ever drove before. If your track has high traction you will want to install the front sway bar first thing otherwise the car has way too much steering. This will get the car close but when a good groove builds in the track the car will start to get really tight again and will want to roll/tip on quick change backs. Try putting a 1mm shim between the front wheel hex and the rim, then move the front RC to +.75. This should make the car very competitive. This car has been by far the best thing I have driven and as more people share set-ups the cars will only get better.
I am running dbl pinks as well but a R9-F and the original 2 piece front suspension holder. (not the re-designed 1 piece)
xray2050 is offline
Old 01-07-2010, 06:36 PM
  #1325
I am not sure what to get the t2 009 or t3 most of the guys that went from the 009 to the t3 are doing worst when using rubber on carpet are most of you t3 guys seeing the same result? I know the t3 should be a step up but what I can see on my local track the 009 is still king on carpet using rubber.
Ramyuras is offline
Old 01-07-2010, 07:49 PM
  #1326
Team EAM
Trader Rating: 79 (100%+)
I know my T3 was better on the first battery than my 009 I ran in Vegas (and it was very good there!!). I have been nothing but happy with mine and have heard the same from everyone I know that has a T3. Especially in rubber tire!
EA
EAMotorsports is offline
Old 01-08-2010, 02:06 AM
  #1327
Trader Rating: 23 (100%+)
I am looking for a set of 6 degree aluminum c hubs for my photon. If anyone has a set they would be willing to sell, please email at [email protected] or pm me. I wont be able to check this thread often, so please email or pm me.
bmcallister is offline
Old 01-08-2010, 04:01 AM
  #1328
heard that in the T3 have problems with cornering speeds? Is it true?
shrugged saying that 009 is mutch faster than T3?
Zooberg is offline
Old 01-08-2010, 07:51 AM
  #1329
What??? The T3 carries more speed in the corners (out of the box) than any other TC I've driven including T2,007,008,009.
pcar951 is offline
Old 01-08-2010, 01:20 PM
  #1330
What is the best body to run for rubber tire on carpet? Is there a certain one that everyone is using?
kobiwan is offline
Old 01-08-2010, 01:23 PM
  #1331
nitrobeast's Avatar
Its seems about 50/50 speed 6 and ltc-r
Old 01-08-2010, 01:34 PM
  #1332
jammincrtjames's Avatar
EA
+1 Car is better
jammincrtjames is offline
Old 01-08-2010, 01:51 PM
  #1333
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
ChristopherKee is offline
Old 01-08-2010, 02:15 PM
  #1334
Originally Posted by ChristopherKee
When the grip comes up real high you have to put the posts back on the car to keep it flat. Thing is most people are using some setups that had the T3 car flex set to soft. But you'll start seeing more setups with rear posts put back in for high grip.
We are also using the older quick roll centers in the rear to shorten the link some for high grip. The L1 L2 feels easy to drive but won't let the rear free up when traction is high, this makes the car feel like it wants to push.
Anyway, after making some of these changes it's really feeling good on high grip surfaces. We are all still new to it on US smaller high grip technical tracks so we're still learning. It is more capable then the T3 once figured out.
okay. I stand in the election of a replacement car to drive with my left Schumacher mi3.5 or switch to mi4 .. But I feel it has run since sst99 Schumacher came on I am going nowhere with their cars longer .. I need to be developed .. Xray is then my choice when I have an old racing friend who is still very active and runs just Xray at the top of Europe! he developed many years ago when he was switching from Schumacher to Xray .. on it was good for him .. so now it's my turn
Soo what are most of the best value for money T3 or 009?
Zooberg is offline
Old 01-08-2010, 03:03 PM
  #1335
