XRAY T3
#617
In looking at the pictures on Xray's forums of one of the broken cars. It looks like (just guessing) maybe the screw wasn't in tight. Like maybe it had backed out a little. That combined with a hard hit I could see causing problems.
Last edited by or8ital; 11-18-2009 at 01:12 PM. Reason: "his" should have said "hit"
#622
many of my friends running T3 without any issues so don't worry
#623
I would just make sure you have plenty of loctite on the screws for the suspension blocks. The fact that is doesn't seem to happen on all T3s really leads me to believe it has to do with the screw not being in tight.
Here are the pictures from the xray forum that lead me to believe this:
#627
Gotcha. I haven't opened my kit yet. It doesn't look to me like he put CA in that area.
You say use Loctite because a loose screw would give the block enough play to pull the screw through, correct? I really can't picture how this could happen with a properly tighten screw either, but that might just be my pea-sized brain acting up.
#628
Again, this is all just a guess.
I agree it doesn't look like he CAed that area. On the Xray forum he claims he CAed the whole chassis including those holes (like the tip sheet says) prior to running the car.
#629
Suspended
I guess all the other 9 cars which my friends sponsor has with the same problem had a screw loose as well
Quite clear xray don't quality test good enough
