XRAY T3
Old 04-06-2010, 07:18 PM
  #1891
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by JayL
I try to have as many colors as possible on my car, helps keep all the bases covered
Haha thats for sure!
Originally Posted by sidecarphil1
yeah more stable on power , the rear grip seams to be increased without running more rear toe ,
i don't know why , i just tried it once and like it
i am going to try 1.5 degrees inboard toe and the 1 degree on the hub
see if this fixes my front end push (understeer)
What body are you running? To get my T3 to steer like I wanted it running a LTCR was the best thing I did. The car doesnt get all upset with the body like past cars did in mod. It works really well with aggressive bodies, and gets rid of that initial/mid corner push
Originally Posted by cyclone x
i got bored so i did that lol with mirrow chrome paint
Lmao! Thats awesome!
BlackedOutREVO is offline
Old 04-06-2010, 08:27 PM
  #1892
dpatterson26's Avatar
Originally Posted by Owen RaCing
And I thought paint pen'ing my Jaco Blues wheels so they looked like SJR black wheels was bad . You gotta post some pictures some place.
I actually took a sharpie to my jaco wheels at a club race a few weeks ago. I had a dark purple body with blacked out wheels, it looked bitchen.
dpatterson26 is offline
Old 04-06-2010, 09:16 PM
  #1893
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Anything with black wheels is bitchen.
Owen RaCing is offline
Old 04-06-2010, 10:29 PM
  #1894
Originally Posted by hanulec
Where is your push? In? Out? Slow? Fast?
on the VERY fast left onto out straight
i am having to come off the gas to turn in then i loose straight line speed and an a sitting duck for the other guys
the car is almost perfect for our track just this small problem , it got better with thicker oil all round 400 rear 500 front
sidecarphil1 is offline
Old 04-07-2010, 12:26 AM
  #1895
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I like chrome, it makes you faster!!
It makes me blind... lol
rx7ttlm is offline
Old 04-07-2010, 04:36 AM
  #1896
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
id suggest going heavier still on your front oil. i looked at the setup you posted on March 17th. I would suggest going to the +0.75 hinge pin holders on the front of your car. When I made that change during the end of indoor carpet season my car started to come alive - reacting very quickly to direction change and completing corners like it has never before. I had my first outing on asphalt with the T3 last weekend -- and i took my same setup and once i put softer springs on the car was actually pretty good.
the setup also shows you running a rear sway bar -- have you tried the car w/o it?
hanulec is offline
Old 04-07-2010, 09:53 AM
  #1897
Big Features's Avatar
I would try shortening the front upper camber link. It will make the car react faster and provide a bit of camber gain for mid-corner steering.
I run both camber links short and high on my T3 for rubber/asphalt. Wakes the car up and allows me to run more droop and softer springs. Our track in very fast with medium bite, if a bit dusty.
Mike
Big Features is offline
Old 04-07-2010, 11:05 AM
  #1898
Mike
ok , how do i shorten the camber links ?? is this with the quick roll centre adjusters ??
also which is the longest/shortest position on the roll centre adjusters ?? 1,2,3 or 4
Old 04-07-2010, 02:00 PM
  #1899
Use position #4 on the quick roll center adjusters. I think the car transitions faster and has more grip mid-corner because of the extra camber gain.
Old 04-08-2010, 07:29 AM
  #1900
Mário Ribeiro's Avatar
I will be running this track next weekend (CRO - Sintra, Portugal) for the 1st round of Portuguese National Champs.
I have a T3, LRP SXX TC and X12 6.5T Motor.
I´m new to TC racing.
Any ideias for a base setup ? gearing ? tyres ?
Thanks for any help.
Track picture in attachment
Mário Ribeiro is offline
Old 04-08-2010, 02:17 PM
  #1901
BigDogRacing's Avatar
It will be extremely loose under normal conditions. If your track has stupid high traction it might be ok, but otherwise it'll be loose. We've already tried it and tried numerous options to counter the looseness, but no avail.
If you do happen to make it work, let us know how you did it.
On the flip side, using 2.5 inner / 1 outer for 3.5 total will really help on a loose track or with big power
BigDogRacing is offline
Old 04-09-2010, 01:04 PM
  #1902
tried this
didn't work for me
Old 04-09-2010, 01:18 PM
  #1903
i thought the +75 hinge pin holders removed grip ??
i will go harder on the oil all round see if this helps , also going to try softer springs
i am maybe thinking that is is just me wanting too much through that corner
Old 04-09-2010, 02:56 PM
  #1904
tried this
didn't work for me
What body are you running? And are you running the chassis posts?
Old 04-09-2010, 06:34 PM
  #1905
Skiddins's Avatar
The +75 holders can sometimes reduce grip but should increase the steering reaction time.
Try narrowing the front track at the wishbones to 1.15mm shims
Skiddins is offline
