ALUM. Steering knuckles for TC3
#18
Originally posted by N4S
Howard , their prices are per pair. When they were released for the tc3 they were just as expensive as the other companies but when they didnt sell they started blowing them out. I have bought just about everything crc made for the tc3 and it all pretty much sucked. the front and rear arm blocks i got from them were so far off it was pathetic. The company has some awesome stuff , but when they tried their hand at the aluminum hop ups they waisted their time.
#19
Originally posted by dtm
Well...I don't run for BMI! But a lot of the CRC stuff is rebadged GPM.....
Thanks for clearing that up!
#20
My CRC steering blocks and c-hubs for the TC3 are working perfect. Fit and finish is great. Clearly better than the GPM units I had before.
#21
I am not an experienced racer - but here's my 2 cents on alum knuckles for the TC3.
I have the Jet knuckles for the TC3 and they seem very nice, except the bearings fit VERY tight.
I also have the JT Racing knuckles for the TC3, and the bearings in those fit tight as well.
My concern with the JT Racing knuckles is, they don't have that ridge in the middle that prevents the bearings from being pushed clear through. They won't fall out because the pin through the drive shaft holds them, but I've noticed that outer bearing will slide in a little (just a mm) and then the pin will rub on the knuckle...
Does anyone know of any other manufacturer that makes aluminum knuckles for the TC3 that are Silver in color?
#22
The crc stuff is not made by crc but by fastrax don't touch anything made by fastrax for the tc3 they seem to have tolerance problems.
#23
The Losi Knuckles you use are they aluminum or regular?
