Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#4517
#4518
Some stuff I forgot to ask... as I was trying to find bodies, I see that there are variations in front width of the cars. Since I don't have an adjustable front width on mine, and I know I would not be able to stand the tires being tucked way inside the body, what ones would fit a RC10L2 in the front correctly?
I would really prefer a larger canopy style car, as the newest bodies with the tiny canopy look goofy. I would LOVE a Porsche 962, but I see the MIX 962 has a 232mm front end, so that sounds like it is out. Any decent options for a Porsche?
How does the Associated Nissan GTP measure up front?
What about AndysRC bodies now that he is doing them again?
And I see there is a Vans Lowla for sale on here... is there someone who could make some copies of it reasonably?
I always loved the Lola T92 Group C cars growing up, would be neat to see a decent RC version, would love any pics/examples of one in use.
#4519
Bulkheads for the first version will be older style Zen pod ones. I've already got a refinement in mind for the future there but I don't have to pay for them as is do no rush.
Most other bits will be Zen, Xenon and Roche.
There will be at least 3 iterations of the car. Stock 12th style then a different front end and the rear end setup.
#4521
#4523
Here is the post for the bell crank system.
https://www.ebay.com/itm/Yokomo-5mm-...-/132031975364
Bearings
http://banzaihobby.com/Yokomo-BB-85-4
Bearings
#4524
Another option is to add a suspension cross plate on your chassis for the wider bodies (space the suspension out further). This will involve a bit of fabrication, but might be an option.
#4525
The Protoform 905B has a larger canopy than the newer bodies like the Saxo or Swift. It should fit a 10L2 well.
With so many kits using Associated suspension, one of the existing pieces from somewhere would have to be a bolt-on fit, right?
#4526
#4527
That's interesting. I had thought about using Awesomatix suspension too.
#4528
In the front? It would mean that you would have moving lower arms, which is largely prohibited in the category right?
#4530
