Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#3916
Could you post a picture with your normal setup in the car so i can see the layout ?
#3917
Center shock position wgt 200mm
Hi!
May I ask question about center shock position?
I wonder how it change behaviour of car at same track. ETS carpet, high grip,
38lilacs with strip tires.
1st shock position like 10R5, which means shock is more rearward.
2nd shock postion like 10R5.1, which means shock is more forward, like 10-12mm
What will be changed?
I am looking for better setup of my custom chassis
Regards
m.
ps: before made parts want to get info, maybe it is not worth?
ps1: my car:
Regards
m.
ps1: my car:
#3918
Any pictures yet of the Roche P10W 235 after assembly ? Would like to see one with the electronics mounted.
Really am in doubt between the VBC Lightning and the Roche.
#3919
what is a starting 13.5 2s starting roll out? getting a car ready for cleveland!
#3921
CRC Pro 10
Wondering the effects on a wider rear pod to CRC GenX LE, with IRS or stock hubs?
#3922
Go for a wider rearpod... With IRS 2135 axle kit... Better balance in the rear axle and a more rigid car.
#3923
Advice on conversion parts
Hiya folks,
I have 2 corally CCT Andy want to convert them to 235mm cars. What parts do I need? And where can I get them online?
Thanks for all the help!
Alexander
Alexander
#3925
Small question: if you see tires in a webshop for WGT then i assume they also fit a Pro 10 ?
#3927
#3930
