Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#3286
Trader Rating: 89 (100%+)
Gearing
I am looking for gearing info ?
What is being run ? 48 P or 64p
And any recommendation on FDR ?
Gearing ? Tire size ? Also Compounds for asphalt or carpet?
Thx!
Thx!
#3287
We use 48pitch.
We work with rollout and not a FDR. This is because the tire diameter changes. Mostly I run outdoor and I use 40sh in the front and 35sh in the rear. Never run it on carpet. Sizes, in the rear around 60 and front 1 or 2 mm less
#3288
Rollout
What is s good starting point for rollout 13.5 / 2s on a med size track ?
#3289
#3290
My friend Magnus and I did some tests with front end damper tubes yesterday on the Vorlon. Works quite well. Same tubes but two different solutions.
/Carl
/Carl
#3292
Good news, found a place with most parts except the rear axle and hubs so the only way out is the IRS complete axle. Now that I'm on a spending spree can you cool guys recommend good upgrades to have? Don't intend to race seriously would be interested in durability stuff mainly.
#3293
The goal was to have the same feeling as with lube on the kingpin. I was fed-up cleaning and lubing the king pins and the dirt the lube collects destroys the pivot balls and arms.
The damper tubes from Yokomo R12 C3.1. Upper arm eyelet from Associated.
#3295
Old news about lubing the kingpins
But what has been said before, it attracks a lot of dust and you need to check and clean is every heat to get the best result.
Seen the damper conversion on the front end also but in a different way.
They mount it between the front end.
Going to look if i can find a pic of it and post it.
Regards Roy
Regards Roy
#3298
How is the fiberglass arm hold in place?
Is it glued on to the uppe arm?
Seen a real cool variant on the Dfr Falcon!
RG Magnus
RG Magnus
#3299
