New Team CRC Gen-XL
#721
Dumper is pulling long hours back at headquarters. I text him today and Frank was crackin' the whip so they can fill orders. I will try to post my 17.5 no-boost 12th and 13.5 wgt no-boost iic set ups here. If it fails, pm me with your email and I will get it to you.
#723
#724
#725
#727
im serious, they even drive the same car.
#728
#729
whats the difference in the setup on left to the one on right,Im new to 1/12 scale,the one on right looks like stock setup,the one on left has different setup around center pivot on bottom,one has thicker top plate and the other has a thinner
#730
The new stuff if all on the right.
The center pivot is now one molded piece. It's really cool since it's way easier to build, cheaper, and it seems to last a little longer too!
The top plate/shock mount is just thicker for less flex. CRC tends to do many small refinements to the cars over time, and that ensures you're super quick on the track. All of these parts are available, and I'm pretty sure newer kits have it all included in there .
Hope that helps
-Korey
Hope that helps
-Korey
#731
dumper's theme song:
http://www.youtube.com/watch?v=OYws8biwOYc
#732
the one on the right also has no dampener tubes
#733
The one on the right has what looks like silver side springs as well as aluminum castor blocks. It appears they are both using the longer CF steering block extensions as well.
#735
I have some of the dual upper, i guess i will swap out..whats the diff between the standard like short ones verse the longer uppers??
