PICK 7 Classes for On-Road Carpet
#47
#48
#51
and that was because they limited to only 10 cars total and 4 of the drivers dropped out cause cars werent ready and they werent allowing others to take the place of the drivers that dropped..... BUT F1 will make a come back in RC but not sure where at Huge race in Ca for F1 and nothing but F1's in Sept
#52
VTA
13.5 rubber
mod rubber
stock 12 single cell
13.5 12 single cell
mod 12 single cell
WGT 10.5 single cell
13.5 rubber
mod rubber
13.5 12 single cell
mod 12 single cell
#53
17.5 Rubber TC
13.5 Rubber TC
Mod Rubber TC
1/12 13.5 1S
1/12 10.5 1S
1/12 Mod 1S
WGT 10.5 1S
It would be nice to see the fewer classes packed with more drivers at the Snowbirds in 2010.
13.5 Rubber TC
Mod Rubber TC
1/12 13.5 1S
1/12 10.5 1S
1/12 Mod 1S
WGT 10.5 1S
#54
mod foam
13.5 foam
mod 1/12
17.5 1/12
mod rubber
13.5 rubber
VTA
13.5 foam
mod 1/12
17.5 1/12
mod rubber
13.5 rubber
VTA
#55
if you are looking for larger turn-out you have to look at what affordable on local and big events....If a racer can race locally on the same euipment as at a large events like the Birds...he/she will more likely attend, cause he wont have to buy alot of extra stuff, plus his car is setup for the most part....when you look at the state of on-road r/c, we need classes that have national rules that allow anyone at the club level to go and try his or her luck at the big boys races.
VTA is a must, cause it has helped the on-road classes so much over the past 2 years...plus everybody needs a relaxed class to run in...this is for "Independents"..sponsored drivers should avoid this class...not to say they cant run it...but should avoid...if possible
or
RCGT...look at VTA
12th scale whatever is the strongest class for the elite r/c racers...a mix of "PRO" and "indies"...
TC 17.5 rubber spec tire...this is a stock class....if you run a spec tire it will allow "JOE BLOW" to get his feet wet on a large scale race...this is another class that will keep cost down....for those not into VTA/RCGT...its also mostly for "indies" but sponsored drivers should run without reward(no trophy or payout)...its a good measuring stick for up and coming TC racers...
TC 13.5 foam...is for the guys trying to get to mod TC...money isnt an option due to the several set of tires they go through in a weekend of racing...or in case of the BIRDS...a week worth...this class isnt for everybody and those who sandbag to win just suck anyway...get in MOD!...once again its a mix like 12th scale, cause you maybe to hang with the sponsored guys but need more "REAL" races against the big boys to make a good jump
TC MOD FOAM...top of the line for ele on-road racing...all the top guys and sponsored guys run this class...very little independents run this class...if any!
this is my take on this...no need to bash any class, we just need to get as much carpet burn as possible...this will be my first year at the BIRDS and VTA/RCGT and 17.5 TC will be my poison...look for me
or
RCGT...look at VTA
#57
or
RCGT...look at VTA
or
RCGT...look at VTA
#58
I'm going to say just cut it down to 5..
I know I posted 7 earlier, but 5 just bunches up entries even more, making for better racing.
17.5 Rubber TC
Modified Rubber TC
17.5 1/12 Scale
Modified 1/12 Scale
WGT 13.5
Privateers run Stock classes, sponsored drivers run Modified, and WGT at this point have a mix of both.
17.5 Rubber TC
Modified Rubber TC
17.5 1/12 Scale
Modified 1/12 Scale
WGT 13.5
#59
17.5 foam and rubber(amatuers only)
13.5 foam and rubber
mod sedan foam or rubber
1/12th stock and mod
WGT
thats 8 classes. i belive that would work.
WGT
