Old 07-27-2009, 07:55 PM   #1
haywood's Avatar
Trader Rating: 49 (100%+)
Default TURBO 35 WITH LIPO UPGRADE
Guys,I just recieved my charger back from a software and lipo upgrade and was wondering what others are using for balancers with these units with the small gauge wire leads?Thanks for the help.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-27-2009, 08:12 PM   #2
Con
The small gauge wire leads are for total batt voltage reading.They use the voltage reading wires to get a more acuate voltage reading.Attach the leads on the batt side of your connector.DO NOT use the charger without attaching the leads...batt voltage will go to high (8.5v).I found this out by accident and ruined two LiPo batts.At first I thought "COOL higher voltage=more speed" and it was a rocket for a while,but then the Batts started to go very flat after 3mins. I use the Astro Blinky the balance charge the batts
Con is offline   Reply With Quote
Old 07-27-2009, 08:21 PM   #3
haywood's Avatar
I am looking for a clean simple layout,are you guys removing the small alligator clips and going to deans?
Old 07-27-2009, 08:23 PM   #4
BBSpence's Avatar
Trader Rating: 46 (100%+)
I use the ElectriFly Equinox with my GFX.
BBSpence is offline   Reply With Quote
Old 07-27-2009, 08:28 PM   #5
Yeti35's Avatar
I am using what he is using but only in the Checkpoint version. It works great for me.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 07-28-2009, 05:25 AM   #6
abailey21's Avatar
Trader Rating: 36 (100%+)
The new losi looks pretty awesome
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-28-2009, 11:40 AM   #7
DriftDreamer06's Avatar
never heard or thought of those?
DriftDreamer06 is offline   Reply With Quote
Old 07-28-2009, 11:44 AM   #8
How did you connect the Blinky to the small black and red leads from the charger?
Sponsored by mooby 64
outlandr91 is offline   Reply With Quote
Old 07-28-2009, 11:51 AM   #9
abailey21's Avatar
I don't think you would, I have my sensor leads just wired to the dean's and the blinky would be separate
K.C.C.O.
