Old 07-28-2009, 12:39 PM   #1
Default New to On-Road... Servo Help Please :)
I am new to on-road and just purchased a used 007 from a forum member. I have a HiTec HS5945MG from my Factory T4 truck and since I'll be spending all of my time getting to learn on-road, I was thinking about using that servo along with my GTB. The class that I plan to run is the Stock Sedan (which is the lowest available class at my local track... no VTA ).
Here are the specs for the servo I have:
Class: Standard
Digital: Yes
Programmable: Yes
Voltage: 4.8v or 6.0v
General Specs:
- Bearings: Dual BB
- Gears: See Notes
- 60 speed: .16 sec @ 4.8v
- 60 speed: .13 sec @ 6.0v
- Torque: 153.00 oz/in @ 4.8v
- Torque: 181.00 oz/in @ 6.0v
-- 1.20 x.80x1.50 inches
Is that enough or do I need more speed/torque? Thanks for your help.
t4tx is offline   Reply With Quote
Old 07-28-2009, 12:54 PM   #2
Foxxrocket's Avatar
Class: Standard
Digital: Yes
Programmable: Yes
General Specs:
- Bearings: Dual BB
- Gears: See Notes
That servo should be perfect for Stock Sedan.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-28-2009, 12:56 PM   #3
Thanks. Is there a "rule" about minimum speed and/or torque? Just wondering what the parameters are.
Old 07-28-2009, 01:22 PM   #4
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
the 'rule' people like to go by is .10sec/100oz*in. however, you can mess with your linkage ratios to make slow servos faster, and weak servos stronger.
in short, the servo you have will be fine.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
