KO PROPO EX-10 Helios q's
#1291
im sorry for bothering you, im a dumb***. it wound up that the servo horn i was using was stripped out... thanks for the help
#1292
hey robert.i was rebuilding my car and then suddenly...........the receiver antenna wire was cut by nearly an inch.should i be worried???will it cause significant range issues???coz i got a race next tuesday,can't really send it for repair.should i be worried???thanks
#1293
hey anyone here doen the spektrum antenna mod on the helios?
#1294
#1295
Originally Posted by noobie
if you want, just add a bit of lenght to the end of the wire... just solder a bit extra wire on and heat shrink it... it very easy
wut if i don't solder the wire???
#1296
#1297
You will lose a little range on the car.
#1298
Robert
This may be the wrong place to ask but is the JR Z-1 indentical to the Helios except for the module. Do you guys build it or do they. I know i trust KO quality but i have never had a JR so i dont know what to expect.
#1299
Originally Posted by tcmerf
Robert
#1300
Mr.Morris,
welcome to the Elephant Bar...would you like your usual booth?
Hey are you going to be at Vegas???
#1301
DO I KNOW YOU??
I should be there. Just trying to work out the final details. Are you?
#1302
LMFAO!!!
Yeah man..I'll be there. Hope you can make it...it is gonna be off the chain!!!
#1303
ok thanks robert.i was worried that it will lose significant range.if i want to change the antenna,do i have to send it in for repair or is it available seperately for DIY(do it yourself)???thanks
#1304
#1305
To all that helped me-Spektrum worked flawlessly at the Gate (Indoors,carpet track). I ran a cap on my 12th scale with GTX speed control.
On my Sedan-I ran without a cap and also only had the power save at 3.0 on the Corally MMS3 esc, but no problems. I changed it to 3.5 anyways.
DONT forget to reset your speed controls after installing DSM though!!!
