KO PROPO EX-10 Helios q's >
Old 02-12-2008, 10:37 PM
  #2101
moy
moy's Avatar
try rc-mushroom..
moy is offline
Old 02-13-2008, 01:57 PM
  #2102
4wd Racer is offline
Old 02-13-2008, 02:08 PM
  #2103
Old 02-23-2008, 11:16 PM
  #2104
moy
moy's Avatar
anybody knows where i can buy 40mhz module for helios.
tnx
moy is offline
Old 05-12-2008, 11:42 AM
  #2105
lem2's Avatar
Default Question
Hi! Will this be a direct fit or does it need an adapter?
https://www.ssl-stormerhobbies.com/c...=ns&pn=DYN1969
has anyone tried it?
lem2 is offline
Old 05-12-2008, 05:37 PM
  #2106
Trader Rating: 40 (100%+)
King of B Main is offline
Old 05-13-2008, 08:05 AM
  #2107
Mr. Shookie's Avatar
Yup I have the blue one.
Hope that helps,
-Shookie <><
Mr. Shookie is offline
Old 07-24-2008, 06:53 AM
  #2108
MattWebb's Avatar
My appologies if this has been asked before.
Is it possible to reset the OPT counter/timer? The timer that counts the amount of "ON" time?
Matt.
MattWebb is offline
Old 07-24-2008, 07:09 AM
  #2109
theisgroup's Avatar
Matt.
i think it was push the "+" and "-" button at the same time
theisgroup is offline
Old 07-24-2008, 07:14 AM
  #2110
Yep, that's correct and should work on the Helios, as well as the Mars series also.
Old 07-27-2008, 06:32 AM
  #2111
MattWebb's Avatar
It worked. Many thanks!
MattWebb is offline
Old 07-27-2008, 10:22 AM
  #2112
Flam3b0y's Avatar
can the helios RF-501 module be used in the EX-1 UR?
Flam3b0y is offline
Old 07-27-2008, 06:22 PM
  #2113
kschu's Avatar
Trader Rating: 16 (100%+)
any1 ever encounter glitch using KO gun ??? i'm jus thinking wan to get a KO gun after 3 futaba gun fail on me....
kschu is offline
Old 07-27-2008, 06:41 PM
  #2114
you can't go wrong with a KO. I have both versions of the Helios, never had a glitch. I also have the UR, never had a glitch.
DirtyRacer is offline
Old 07-27-2008, 06:51 PM
  #2115
I just switched from 3PKS with Fasst to a Helios with the new KO 2.4 system. All I can say is AMAZING. The feel of the radio is phenomenal and the 2.4 has so far been flawless.
jon123 is offline
