KO PROPO EX-10 Helios q's >
Old 07-21-2007, 01:59 PM
  #2011
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
WHAT'S THE DIFF. BETWEEN THE 501F AND THE 502F MODULE?
ALSO I'VE BEEN TOLD YOU CAN USE BOTH THE MODULES IN THE EX-10 HELIOS. IS THIS CORRECT.
RED-LINE M03 is offline
Old 07-21-2007, 02:36 PM
  #2012
OH ONE MORE ?
CAN I PURCHASE THE NEW C2 WHEEL FROM KO FOR MY EX-10 HELIOS.
REGARDS....
Old 07-21-2007, 03:20 PM
  #2013
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by nnick
Yes, of course you can change it
I'm using the wheel from my Mars 2000 Special Edition
Originally Posted by RED-LINE M03
OH ONE MORE ?
REGARDS....
Originally Posted by K_King
Is it possible to replace the wheel on the KO?
Id LOVE to get the same sheel on the C2.......
http://www.shopatron.com/img/product...1_KPP80231.jpg
BlackedOutREVO is offline
Old 07-21-2007, 03:21 PM
  #2014
ehh, its a lil mixed up lol
but yes it does it looks like
Old 07-22-2007, 05:39 AM
  #2015
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Originally Posted by TimXLB
VoodooPH:
Hi,
Yes you can use Airtronics crystals in your Ko C2. I use them in my EX 10. also you can use Airtronis 27 band crystals.
Thanks! Oddly the C2 I got is in 40MHz... I assume its the same case. Just as long as i get an Airtronics 40MHz crystal as well? How about Futaba crystals?
VooDooPH is offline
Old 07-22-2007, 06:58 AM
  #2016
Trader Rating: 14 (100%+)
VooDooPH:
Hi,
I haven't tried Futaba crystals as I can't get them as easily as Airtronics. sorry I couldn't be more help.
TimXLB is offline
Old 07-23-2007, 09:19 AM
  #2017
Budman's Avatar
Trader Rating: 22 (100%+)
Can you adjust the trigger tension on the Helios? If so how.
Budman is offline
Old 07-23-2007, 09:33 AM
  #2018
Hebiki's Avatar
Trader Rating: 26 (100%+)
Budman, there is no external adjustments on the trigger tension. What i did to my helios was to open up the radio and replace the spring. i took the spring from a clickable pen, cut it down to length, and installed it. it made the trigger tension a lot higher (stiffer) which made it a lot better for me. have a couple of spare springs in your toolbox though, doing this modification, the spring broke on me during a race and i had to replace it.
Hebiki is offline
Old 07-23-2007, 09:36 AM
  #2019
VooDooPH's Avatar
VooDooPH:
Hi,
no worries! thanks!
cheers!
Jason
VooDooPH is offline
Old 07-23-2007, 10:05 AM
  #2020
Budman's Avatar
Thanks I will give it a try!!!!!!
It felt a little soft to me.
Budman is offline
Old 07-24-2007, 08:56 AM
  #2021
more$thanbrains's Avatar
im not shre is this has been asked allready but can you run two throttle/ break servos on the heilos without using a splitter
like on my spektrum radio you could have one servo by pulling the throttle and another servo by using the break and while one is being used the other one stays at centre
help?
more$thanbrains is offline
Old 07-24-2007, 11:19 AM
  #2022
The 502F is a CPU driven module. It is more effecient and has a faster response from center (more linear).
Yes, you can use either in the EX-10.
KOPROPO TECH is offline
Old 07-24-2007, 11:21 AM
  #2023
OH ONE MORE ?
REGARDS....
Sorry, but the C2 wheel will only be available with the C2 radio.
Old 07-24-2007, 11:24 AM
  #2024
jag88's Avatar
When will the 2.4 gig module/receiver be released ?
Thanks.
jag88 is offline
Old 07-24-2007, 12:29 PM
  #2025
You may set up the third channel to operate a serperate servo.
Please refer to page 57 in your manual for the details.
