KO PROPO EX-10 Helios q's >
Old 08-31-2006, 07:28 AM
  #1756
Rob Phillips's Avatar
Originally Posted by Scottmisfits
Reread your manual for clarification but I beleive it's 2 3/4" that the antenna has to be, not 3.6mm. 3.6mm is about 1/4 of an inch as 25.4mm = 1"
I think he ment 3.6cm
It's actually 3.6 inches, not 2 3/4".
3.6" who came up with that one? You have to have an engineering scale to read in 1/10's of an inch. Millimeters would have been easier than 1/10's.
Rob Phillips is offline
Old 08-31-2006, 07:43 AM
  #1757
Mr. Shookie's Avatar
YUP that is what I meant, sorry for the confusion...
-Shookie <><
Mr. Shookie is offline
Old 08-31-2006, 08:00 AM
  #1758
I knew it was a typo, cause Shookie is always on top of his game.
Old 09-01-2006, 11:19 PM
  #1759
rays_tt's Avatar
Trader Rating: 26 (100%+)
Thanks for all your help fellas, I'm picking up my helios on Monday can't wait I wont be able to sleep till then I know it.
rays_tt is offline
Old 09-02-2006, 12:17 PM
  #1760
XrayFK's Avatar
Anyone else have this problem? I can't adjust the steering balance left and right on my radio, but I can reset it. Once I get to that menu, I can't select left or right. Thanks.
XrayFK is offline
Old 09-02-2006, 12:19 PM
  #1761
You have to turn the steering wheel to the left or right before the adjustments can be made.
Hope that is what the problem is.
-Shookie <><
Old 09-02-2006, 07:34 PM
  #1762
Nexus Racing's Avatar
Like Shookie said, you have to turn the wheel to adjust the EPA, but...
If you are turning the wheel to full throw and don't get the <*> next to the L or R setting, all you have to do is carry through the "adjust VR" function to reset the physical end points, and all will be fixed .
Nexus Racing is offline
Old 09-03-2006, 12:45 PM
  #1763
XrayFK's Avatar
Thanks guys, it's all good now.
XrayFK is offline
Old 09-21-2006, 07:28 PM
  #1764
Core Creations's Avatar
Trader Rating: 108 (100%+)
I'll ask this again as it seems a dozen people have asked and haven't really got any answers.
Is there a way to get some drag brakes by adjusting the transmitter. I am running a GTB/Brushless and the drag brakes on the esc are a joke...I need a way to add some drag while not doing anything hokey. KO STAFF...any ideas??
Core Creations is offline
Old 09-21-2006, 08:13 PM
  #1765
Scottmisfits's Avatar
You should be able to adjust your throttle trim to do it.
Scottmisfits is offline
Old 09-21-2006, 10:34 PM
  #1766
James's Avatar
why dont you program the GTB for more drag brake.. what's factory... 20% or so?
James is offline
Old 09-22-2006, 04:47 AM
  #1767
AngryAsian's Avatar
Not a radio fix - but the new sintered rotor for the GTB is a big plus in terms of drag brake.
Or like others have suggested - turn the drag brake up on the GTB first... program away!
Lastly - don't know about the helios.. but erhm.. throttle trim?
AngryAsian is offline
Old 09-22-2006, 09:42 AM
  #1768
I already have the GTB at maximum drag brake. I'm not sure what your suggesting with the trim...if I adjust the throttle trim to have some drag...won't the ESC not reach full throttle?
Old 09-22-2006, 10:55 AM
  #1769
Nope try the Brake curve.......it will make it come on stronger sooner...
Read the manual about the brake settings in the Radio....
I use it constantly in Nitro...
-Shookie <><
Old 09-22-2006, 11:08 AM
  #1770
jtracker's Avatar
Trader Rating: 28 (97%+)
Hello,
I don't know if this question has already been asked but I just bought a used helios EX-10 and when I turn it on and especially scroll through the different things the letters are pretty dim?? Just wondering if something goes bad with them inside or what? Thanks,
Justin
jtracker is offline
