LRP SXX TC SPEC
#76
@ZW: are you sure you connected the speedo to correct slot (channel 2) and correct polarity to receiver?
Because what you describe happens if there is no signal from receiver! Doublecheck those connections first, maybe swop servo and speedo quickly to see if channel 2 works fine.
#79
Picked me one these up today. I love that it's one the smaller ESC's too. ALot better then my tc spec I have too.
So, going run it mainly in 13.5 and mod. WHat seems to be the best profile for 13.5 outside asphault tracks and being about 100 deg weather days.
thanks,
Edited: Well after reading the pages here, seems like profile 10 for 13.5 with the 5degs timing would be the best best. Maybe dropping a tooth or two too.
thanks,
#80
Hi was just wondering if anybody knows what the timing modes convert to in degrees from 1-5 also does the sxx have the variable timing like the stock spec does. I am running 10.5 and was wondering what would be the best setup for my speedo
#81
Regional Moderator
Can anyone help out with this? Trying to get a new SXX set up for a race tomorrow, and having some problems.
I've got everything hooked up right, and have followed all directions.
When I try to set up the radio by holding the Set button for three seconds, it never goes into the setup mode where you set full throttle, brake, etc.
The unit seems to power up, fan comes on, blue LED comes on, I'm able to get into the power profile setup, but that's it.
Thanks!
Thanks!
#83
what would be better for 10.5 foam on carpet, tc spec or stock spec?
#84
@jrxs-r: that is correct that SXX does not include blue limited-lifetime warranty card anymore as all the new competition speed-controls are no longer covered by that special warranty but only with regular warranty terms.
@sukh: I guess you'll be better off with the SPX StockSpec for 10.5t.
#85
Burrito-
will spx/sxx have issues with single cell voltage applications?does the timing advance or punch still work in single cell 1/12th cars or does the esc start sensing low voltage and limit the timing advance in this low voltage application??? even thou single cell lipo has not gain momentum as wellas 17.5/13.5 in europe this application is going very strong here in states. what say you with regards to this type of racing and esc update??
#89
SXX series speedos do of course have a LiPo cut off function, but it's for 2S cells only and not for 1S.
So, if you use 1S you should disable LiPo cut-off (value #2 in mode.1) and simply stop running when car get's very slow.
