HPI's new F1
Old 02-15-2011, 08:42 AM
  #976
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by THG
Yea the mini lipos are junk. Any one have 1 or 2 they want to sell me cheap?
Originally Posted by Slideaway
Hello guys,
Need help here, any pix showing how to adapt properly a Tamiya F104 Rear Wing on the F Ten ?
You just need to add 6mm spacers for the screws.
Originally Posted by schrammy79
Raced it for the first time 2 weeks ago against Tamiya and 3Racing chasis's and out of the box you will find it very hard to find rear grip. Unless you back right off and coast through the turns you will spin out and result very poor lap times 38 secs (last) with the other brands running fast 23-25 secs laps, During the night I was able to get the super hards to perform scrub in and perform a best lap time of 33secs. After spinning out int he 3rd qualifier and constantly running last and being the first round of the season I saw know piont of continuing.
$250.00 later and waiting on parts to arrive have upgraded all available options in the hope of finding rear grip.If I can't get it with tuning the ball diff and soft tyres I will go and get the Exotek FX10 and convert to foams as I race on asphalt in the evening from 6pm at night. I run a 17.5 LRP V12brushless,Novak GTB esc, savox low profile servo (no servo saver )and spektrum receiver.
Any idea's what complete rim and tyre foam tyres will fit the HPI F10 ( link me) I purchase from USA,ebay, and Hong Kong
I desperatly want to acheive a win for the F10 as HPI is not reperseted well at my club and I really like the brand.
Chris
Going to the options soft front and rear rubber will make a HUGE difference. You may actually feel understeer
MikeR is offline
Old 02-16-2011, 01:16 AM
  #977
schrammy79's Avatar
Trader Rating: 18 (100%+)
Thanks MIke for the feedback cant wait to hit the track now and tear it up!!!
schrammy79 is offline
Old 02-21-2011, 07:13 PM
  #978
Marklar's Avatar
Default Williams FW31 and Renault R29 RTR & kits
Re-Announced at the Nürnberg Toy Fair...
Last edited by Marklar; 02-22-2011 at 06:11 AM. Reason: Re-announced instead of announced...
Marklar is offline
Old 02-27-2011, 08:16 AM
  #979
Any one have a part number for the 12th scale front springs? The track I race on is a little bumpy and my nose is bouncing all over the place.
Teknoron is offline
Old 02-27-2011, 08:22 AM
  #980
Trader Rating: 61 (94%+)
yes ron shoulda asked lol i got one more set like i gave max and aaron..
tcb22185 is offline
Old 02-27-2011, 11:45 PM
  #981
HPI springs, as example:
HPI-61615
HPI-61699
HPI-61696
AE springs:
AS4114
AS4116
AS4117
AS4118
AS4119
dimka_ff is offline
Old 03-02-2011, 09:36 AM
  #982
Default Tires
Is there anything better than the HPI 102906/102907 Bridgestone High Grip slicks?
Teknoron is offline
Old 03-02-2011, 12:48 PM
  #983
schrammy79's Avatar
Converting to a foam setup.have you tried using a traction compound or tyre warmers?
Old 03-02-2011, 01:31 PM
  #984
Track Rules are rubber tires, to keep it somewhat level playing field. I had used the stock tires with compound, then touring tires, which were not too bad. So basically just seeing if it is worth the cost to get the HPI tires or just stick with my touring tires?
Teknoron is offline
Old 03-02-2011, 02:01 PM
  #985
schrammy79's Avatar
Default hpi bridgestone tyres s compound
Answer to your question "no" there is nothing currently out their with extra grip then those tyres you mentioned . as I had the same issues with traction with the stock tyres until I upgraded my racing setup. With traction compound I use wd 40 on my tyres spraying a little on a rag and wiping the surface of the tyre and allowing it to dry . And when racing go old simply green
Old 03-02-2011, 08:14 PM
  #986
In all my pan cars it seemed that I only got rear grip when I drpped my rear ride height to 4mm or under!!! It worked wonders with rubber tires!!!!!!
bertrandsv87 is offline
Old 03-08-2011, 10:55 PM
  #987
lightfoot's Avatar
Default UF1 Series
2011 UF1 season will start this Saturday at West Australian Coast Grand Prix...
8 races , 8 tracks, 1 race per month, 1 2011 UF1 Champion...
For details, check out:
http://www.charleslightfoot.com/UF1/UF1_home.html
lightfoot is offline
Old 03-10-2011, 02:29 AM
  #988
4j's's Avatar
Trader Rating: 24 (100%+)
Hi guys both a 2nd hand hpi formula 10 without manual
Can somebody give me a link of manual i can download
And what is the internal drive ratio for this kit.
Do you have suggestion FDR for silver can brush motor
Thanks.
4j's is offline
Old 03-10-2011, 02:53 AM
  #989
lochness42's Avatar
Thanks.
http://www.hpieurope.com/instruction...&partNo=102852
everything is in manual. to FDR for silver can - I don't really know -> hopefully someone else will answer that
lochness42 is offline
Old 03-10-2011, 03:12 AM
  #990
schrammy79's Avatar
FDR for the F 10th is 1:1 direct drive mate
