Like Tree65Likes
TC3 Forum
Old 05-17-2020 | 08:51 AM
  #12211
angrymelon's Avatar
Originally Posted by Woof6
ok, kewl. looks like if I stay in the 40's I should be alright from what I've read. Thank you. Will the xray spurs work? Considering the Axon DTS spurs
I'm not sure about the Xray spurs. I was using the white Robinson Racing spurs at one point.
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXYGN3
I believe I switched to 64 pitch, but they were also Kimbrough, just black in color. Let me dig out my TC3 and see.
angrymelon is offline
Old 05-17-2020 | 12:39 PM
  #12212
I use the Robinson Racing 64P spurs gears and use a 73T machined spur and 48T pinion in my TC3 giving a 3.80 FDR for the USGT class.
SteveM is offline
Old 05-17-2020 | 02:25 PM
  #12213
angrymelon's Avatar
So the last time I ran the car I was using a 72T Kimbrough 64 pitch. They are the same spurs that we were using for pan cars like 1/12 and F1.
Old 05-17-2020 | 02:29 PM
  #12214
The stock setup is a 48 pitch 72 tooth spur.
SteveM is offline
Old 05-17-2020 | 02:38 PM
  #12215
angrymelon's Avatar
Right, I think in the end I switched to the 64 pitch so I could run a much larger pinion gear to get the FDR low enough, as compared to the 48 pitch spurs.
Old 05-17-2020 | 03:33 PM
  #12216
gigaplex's Avatar
I'm not sure how 64p would help with that. Both pitches come with large pinion and small spur options.
gigaplex is offline
Old 05-17-2020 | 03:54 PM
  #12217
angrymelon's Avatar
But a 72T 64 pitch spur is much smaller than a 72T 48 pitch spur is it not? Because of that, with a 72T 64 pitch spur I could fit a much larger pinion than with a 72T 48 pitch spur. Granted you can run a small 48 pitch spur like a 52T, but if memory serves, those were harder to come by, and you don't get the potential benefits of the smaller gear pitch as well.
Old 05-17-2020 | 05:08 PM
  #12218
Woof6's Avatar
ty all for the responses. you've answered all my questions. can't wait to get back racing
angrymelon likes this.
Woof6 is offline
Old 05-17-2020 | 05:10 PM
  #12219
gigaplex's Avatar
That's why you use a 54 or 55T 48p spur to replace a 72T 64p spur. Take your 64 pitch gear, divide the tooth count by 64 then multiply by 48, and you get your equivalent sized 48 pitch gear. You never just look for identical tooth counts when changing pitch.
I have a 55T 48p Robinson Racing spur in my TC3. When I fit my 43T pinion, I get down to a 3.2 ratio.
Regarding the benefits of smaller pitched gears, sure. That's a valid reason. "48p won't fit" is not.
gigaplex is offline
Old 05-17-2020 | 08:00 PM
  #12220
angrymelon's Avatar
I must've remembered incorrectly. For some reason I thought there were 48P size limitations to get down into super low FDRs due to motor mount not having enough adjustment. That and not having as granular of ratio changes. If not, party on
Old 05-29-2020 | 05:44 PM
  #12221
OVA's Avatar
OVA
OVA is offline
Old 06-16-2020 | 01:21 PM
  #12222
Woof6's Avatar
Have another question. My used kit came with a bunch of front block carriers. Looked them all over closely, but see nothing that says 0, 2, or 4 degree on them. 3 do have white out 4l or 4r on them. Any way to tell the difference?
Woof6 is offline
Old 06-16-2020 | 04:10 PM
  #12223
OVA's Avatar
OVA
.they must be the plastic 0 deg C-hub..no need to have Left or right mark
OVA is offline
Old 06-16-2020 | 04:12 PM
  #12224
DaSilva3525's Avatar
OVA You just trolling thus thread time to time?
DaSilva3525 is offline
Old 06-16-2020 | 04:22 PM
  #12225
OVA's Avatar
OVA
Oh $hit
Actually I have the TC4 with the Kaizen with ton of modification done
I came across alot of spares unknown parts in my pit box
just posted the pics TC4 thread
OVA is offline
