-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
Aries326 09-20-2005 08:34 PM
Anthony, thanks for the tips. I'll mess around with the swaybars this weekend. I just switched to all ball diffs. I can't wait to try that out. Do you drift at Arai?
anthony390 09-20-2005 08:41 PM
actually i dont go to tracks i just mess around with my friends and niebors by the near by vacant parking lot because the surface is nice and smooth :smile: :smile: :smile:
well your welcome if you have a pis of your tc3 post it up so i can see what ur set up is and car mods so i can even help u more ;)
anthony390 09-20-2005 08:43 PM
hey your b-day is my dads (march 26) and mine is march 27 lol :smile:
Aries326 09-20-2005 09:16 PM
Dude, that's funny! How the hell did your Dad manage to get your Bday close to his? He must have timed it!
Anyway, try out the website http://www.driftrcentral.com Alot of peeps from all over the world hang out there and discuss drifting, share paintjobs, tips, etc... They even hold rc drift competitions at Irwindale Speedway. GroovyDrift had a competition there last month. Those guys do some sick drifting... Anyway, Arai is the name of a garage they hang out at on weekends and hold drift meets. They do some sick tandem drifting. Have you seen their videos before?
Here's my drift setup:
3 degree toe in rear, no toe in front
0 camber all around
shocks placed in suggested holes in shock towers
silver springs in front, green in rear
droop screws are pulled all the way up
I've got the NTC3 Steering rack and my battery is pulled to the center. I've been able to get some real long drifts but when it comes to complicated drifts like going through S-turns, I can't do 'em. I tend to over drift or the car spins out. I finally put ball diffs in both front and rear so I'll test it out this weekend. Thanks again for any tips...
Here's my FT TC3:
http://i7.photobucket.com/albums/y27...s/IMG_1056.jpg
anthony390 09-20-2005 09:33 PM
try to get 0 or 1 degrees in the rear toe that might help some and put just barly negative camber in the rear so you wont slide out as easily and so u can mantain your angel also put a small spacer in you ntc3 steering rack to reduce some ankerman. All that sould help you alot on the s-turn and everything else and one more thing what kind of diff did u run before the ball diffs?
HOPE it helps
anthony390 09-20-2005 09:43 PM
dude thats the sickest drift video i seen about r/c drifting
anthony390 09-20-2005 09:46 PM
BUT the thing is the way they turn, they under steer and dont counter steer all the way thruogh the turn and that makes it not really drifting
Aries326 09-21-2005 02:22 AM
When I first got my used TC3, the spool was in the front and the ball diff was in the back. What a disaster. I then moved the spool in back and had ball diffs in front. Then I put a one-way in the front spool in back. I moved back to ball diff in front and spool in back. Now I'm gonna try ball diffs in front and back. Too many changes. That's why the diff case is getting stripped.
Anyway, which drift video did you watch? The Yokomo one? The SG Drift videos are the best edited but GroovyDrift's Arai drift sessions have some sick drifting. The video from the GroovyDrift Battle has some sick tandem drifting. PM me your AIM SN and I'll let you download those videos from my folder. Alot of these videos aren't being hosted anywhere anymore... There's a bunch of other drift videos out there that people just throw together for fun but they're not as good.
anthony390 09-21-2005 06:46 AM
i dont have aim or sn and i whatd the yanabe arena one
rivbluenoma 09-22-2005 03:23 PM
Just got a used tc3 on a trade yesterday. Little different than the other cars that I own. Something Im not sure about. The rear hubs have about 1/8" forward/rearward play(slop). Should there be shims or spaces on the pins that the hubs ride on to keep them from slopping around in the arms? Also, is there a fix to keep the pins in the arms/hubs from backing out?
anthony390 09-22-2005 05:04 PM
there should be plastic spacers in the rear hub because the tc3 has adjustable wheel base
rcnutmich 09-22-2005 06:39 PM
4 Attachment(s)
hello everyone...my son and i are just getting into on road, raced about 6 times now, it has been a blast
anthony390 09-22-2005 08:05 PM
Hec ya man another road racer any wayz what have u been doin b4
graphiteman 09-22-2005 10:20 PM
TC3
rivbluenoma-
There are 2 small plastic shims that fit onto the lower pin. To secure the pin, there is a small setscrew on the upright (hub). If the setscrew is not in place (or tight enough), the pin will move and eventually rub on the wheel.
rivbluenoma 09-22-2005 10:21 PM
Like I said before, Im new to touring cars so this may be a dumb question. Why is it that when I turn one way the car turns fine, but when I turn the other way the car spins out? It looks like everything is set up the same on both sides.
