hey i was wondern if the wheel base from the tc4 is the same as the tc3 and whats the difference in the dog bones
Originally Posted by graphiteman
I decided to try the Losi XXX- rear hubs, and the CVD driveshaft will not reach the drive cups unless I run an excessive amount of camber. Is there a differential drive cup that is a bit longer so I can give these hubs a try?
i have losi hubs all the way around on my tc3 and they work great.never broke one :sneaky: |
Originally Posted by tom235
make sure your not running the losi off set hubs then you need a ton of camber.
Originally Posted by Aries326
What are the part numbers to those losi hubs? I've got losi hubs NIP for the fronts that came with my TC3 that I bought, but I don't have any for the rear. Thanks.
Don't forget A-9847 are the 0 degree graphite hubs. R.W.
-2 degrees kick?
Hey guys. I'm setting up my FT TC3 for carpet, and using Blackstock's Snowbirds setup for a starting point. How can I achieve -2 degrees of front kickup? I thought you can only go +2 or 0 degrees...
Second, is this a pretty good setup to start with, or am I better off using AE's carpet setup in the back of the owner's manual? The track is Ozite, lots of tight 90 and 180 degree corners, one short straight. |
he tells you how on the "ask Mike Blackstock thread" on this forum.
here are the losi #'s 1/2 deg 9852 1 deg 9853
Thanks! |
Thanks DLM. Can you save me some time, what page is this on? (30 pages)
Use the F+0 block & put .032" spacers under the rear block.
TC3 Tub Chassis Mod
I have found that once I modified my tub chassis to get the battery packs more to the center, the chassis is not as stiff. I know this is because I have removed material from the center beam, but does anyone know of a way to counter act this?
Thanks, Yekim |
BMI
BMI makes a uppper deck for the tub chassis that will stiffen it back up.
I picked up the wrong parts, so thanks for the info pertaining to the Losi hubs and part numbers!
Do those of you running the Losi hubs leave the ball cup on top when installed? It leaves the camber link at an odd angle. |
Yes, leave it on top. You may need to shave a little off the top with an Exacto off the ballcup for wheel clearance. The do angle forward some but work fine.
I like to try different setup's, any new tc3 setup with spool diff.
| All times are GMT -7. It is currently 09:54 PM. |
