-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
Speedie 11-27-2003 04:52 PM
1 Attachment(s)
Originally posted by tc3stocker
hey, lets all post our pictures of our TC3's or any other cars for the holiday season
Here is my TC3.
protc3 11-27-2003 04:55 PM
here is my car
protc3 11-27-2003 05:00 PM
1 Attachment(s)
one more try
Bubblestc3 11-27-2003 09:31 PM
Originally posted by fatbear
Hi I am new to the forum, I hope someone can help me out.
I have been racing TC3's ever since they come out in the modified class. I am just in the process of putting a new chassis on one of my cars and have noticed that there is a spot that binds badly when you rotate the diffs in the front and rear housing. It is only when bothe diffsa nd the drive shaft are installed. I have always noticed a small amount of binding in the gearboxes but never this bad. Has anyone got any ideas or maybe solved this problem. I am running Factory team cars with the plastic diffs and the aluminium drive shaft. Also I have noticed that it is even worse with the one way in.
Fatbear
I have also had this happen to one of my cars. To solve it, I rebuilt the diff, with new outdrives, and new bushings for the diff. Basically what happens to make the drivetrain feel this way, the ring gear becomes "off-centered" from the rest of the diff assembly and makes the gear-mesh in the gear boxes tighten and loosen as the drivetrain spins. That is why I change the bushings and the outdrives, to get(hopefully) the ring gear re-centered on it's axis and make it spin in a perfect circle.
TAC3 11-28-2003 02:18 AM
My TAC3
TAC3 11-28-2003 05:41 AM
This is it
1 Attachment(s)
PIC 1, I think I need a new body !!!!!!!!! :( , mazda 6 is the option and I am waiting for it to come in AUS
TAC3 11-28-2003 05:56 AM
PIC 2
1 Attachment(s)
PIC 2
cdoty 11-28-2003 06:44 AM
1 Attachment(s)
I just got my car last week, what a rush! They are a riot to drive. I'm use to racing offroad and thought that that was the stuff. This is a close second!
Pic
jag88 11-28-2003 06:24 PM
I've bought a used TC3 and find that the rear toe in is not equal
from side to side. I've replaced the pins, arms, uprights and the
arm mounts but nothing helps. I remember that this was a problem when the car first came out, anybody out there know
whats wrong and how to fix it ??
Thanks.
PizzaDude 11-29-2003 12:48 AM
Rear toe-in blocks (wheel carrier) were wrong.
Tje mold was crooked where the hingeping hole wa/is.
I personally also replaced the chasssis toe-in blocks.
Speedie 11-29-2003 12:57 AM
I found my rear hubs getting tweaked a few times. (IM still a rookie) I switched to using plastic rear Losi hubs and havent had a problem since. They are holding up better and arent tweakin.
Fasttrak 11-29-2003 01:05 AM
I too had some troubles with the stock ASC rear arm blocks being incorrectly molded, gave one side 2 degrees more then the other. I tried the Tobee Craft Delrin block (R 3+0) and it is dead on perfect side to side and is holding up well. About ten bucks and well worth it in my mind.
lee82gx 11-29-2003 05:12 AM
my Losi hubs have these problems(front)
i bought a pack of 4deg front spindles and i get the left 0 deg's (plastic) and right 4 deg's(carbon).the bad one even comes with 4deg markings....i know i can throw these back to Losi but it's too far....
GTO2 11-29-2003 06:01 AM
Is it a coincidence or ?
I just notice that my TC3 front block carriers are exactly identical. Being so the left one is leaning towards backside of the arm,
and the right one is leaning towards frontside of the arm.
I can see the steering throw is not symetrical between left and right because of this.
Thinking it is wrong and need correction, I get myself a new pair of Front Block Carriers p/n 3869 0° Graphite.
To my surprise, they are identical as well....is this normal?
Else I have to sand them. :(
Nexus 11-29-2003 08:05 AM
GTO2
you don't need to sand them...it's fine and the car works fine with it. that has been discussed tons of times on this and other TC3 threads. that is how they are designed.
besides you don't need full 100% steering throw at race speeds. i run a bone stock FT TC3 with no milling, sanding, shimming, ect. and have won and placed consistantly in the A Main at my track.
