Like Tree65Likes
TC3 Forum
Old 08-21-2003, 05:47 PM
  #5881
Brian McGreevy's Avatar
Well unless you have a stand under that car stand, the air you'd be sucking from the motor would stay there and stay warm. Plus you want to blow the hot air away, so having blowing towards the motor.
Brian McGreevy is offline
Old 08-21-2003, 05:54 PM
  #5882
ajg
Registered User
ajg's Avatar
Default Tc3 setup
What setup should I use for a tc3? I race on vht or soda with Jaco double purples in front and purples in back, I also use paragon traction compound.
I have a stock racer kit.
I currently have:
2 degrees camber all around
3 degrees toe-in on the rear
0 degrees toe-in/out on the front
2 degrees caster on the front
2 degrees kickup on the front
5mm ride height in front
5mm ride height in rear
2 degees anti-squat in rear
medium wheelbase
40 wt shock oil in rear
60 wt shock oil in front
droop gauge #6 in front
droop gauge #4 in rear
gold springs in front
silver springs in rear
top outermost top shock location all around
bottom innermost camber link location all around
and the battery pack in front.
ajg is offline
Old 08-21-2003, 08:14 PM
  #5883
=MisFitz= NuKe's Avatar
jesus, you should have like.....TONS of rear traction, although except for the front battery position. I would move that to the back, when it is in the front of the car, you shift so much weight to the front it is rediculous, also, try 2 degrees rear toe, and 1.5 camber all the way around.
=MisFitz= NuKe is offline
Old 08-24-2003, 09:10 AM
  #5884
hey guys my friend just bought some Hardcore racing outdrives for his F/R diffs and when he started assembling them he noticed that they dindt fit like the original on the locknut side theres no place for the spring!
Anyways is there a different way of assembling these outdrives compared to the originals?
crono man is offline
Old 08-24-2003, 01:27 PM
  #5885
The original steel and the newer composite drives assemble differently. I figure hardcore copied the steel drives, so if you are use to the composite outdrives of associated thats why your having problems.
patcollins is offline
Old 08-24-2003, 05:06 PM
  #5886
lem2's Avatar
Default out drives
like the steel out drives of the associated, the spring should go on the other half of the diff as opposed to the composite outdrives. Peace and happy racing!!!
lem2 is offline
Old 08-24-2003, 06:54 PM
  #5887
but the hardcore outdrives seem to be made like the composite associated outdrives not the steel ones
Old 08-24-2003, 08:41 PM
  #5888
Trying to locate the store I once saw some Delrin diff outdrives for the TC3. Spent the last two hours hunting through webistes to no avail... If anyone knows of a store the sells them, I would very much appreciate the link.
Fasttrak is offline
Old 08-24-2003, 09:29 PM
  #5889
lem2's Avatar
Default Delrin outdrives
www.rainbowten.co.jp
www.rcmodel.com.hk
its the one by rc-square
you can see them at www.rc-square.com
peace and happy racing!!!
lem2 is offline
Old 08-24-2003, 09:36 PM
  #5890
Here too Fasttrak; http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=216
ZER01 is offline
Old 08-24-2003, 09:51 PM
  #5891
Thanks guys, really appreciate it, should have just asked before spending half the night browsing for all over the internet
Fasttrak is offline
Old 08-26-2003, 09:17 PM
  #5892
Registered User
Guys, I still haven't build my tc3 yet, but I have one question to ask. I bought RD Logics Die-cast aluminum differential cases F/R for TC3. I don't know I should use it or not because its kinda heavy. Is it better to install it or its just for look?
Aku-Man is offline
Old 08-26-2003, 09:48 PM
  #5893
Aku-Man,
I have seen the Rdlogics case and found them to be fairly poor quality, almost a pot-metal casting. They would add more weight, still require you to clean out the bearing journals for propper fit and add almost nothing besides less chance of stripped screws. I should be getting the Warp Speed blueprinted cases later this week and think these are a much better purchase. For $45.00 delivered you get both cases that have been properly cleared journals for free spinning bearings without gauging material with a Dremel tool. They then take the screw holes and ream them out and use steel thread inserts to eliminate stripped plastic screw holes. Will let you know what I think of them when I get them installed.
Fasttrak is offline
Old 08-26-2003, 10:45 PM
  #5894
Registered User
Great, I will be waiting.
Aku-Man is offline
Old 08-26-2003, 11:03 PM
  #5895
Aku-Man,
Aku-Ken, you don't need impregnated steel screw cases for the screws-man that sounded w i c k e d-that is if you know how and when to tighten yo screws.
ZER01 is offline
