Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 03-14-2011, 11:21 AM
  #4741
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by j.d.roost
Can someone tell me the rate of the 104 pro white spring?
It says med. in the parts diagram but when you
look up Tamiya springs all the white springs are listed as extra stiff?
Need a stiffer spring but not sure what to use..
Red dot = 12.5lbs
Next one up is yellow = apprx 13.5lbs
MikeR is offline
Old 03-14-2011, 11:25 AM
  #4742
Oortael's Avatar
Originally Posted by robk
This will have more effect if we can close all gaps between body and chassis. Did you seal the motor mount?
Oortael is offline
Old 03-14-2011, 11:58 AM
  #4743
Pro10noob's Avatar
That looks alot like the F103 Tamiya diffuser i have on my car
Nice
regards Roy
Diffusers actually work if they are fairly large. I made one, ran it-which stuck the car enough that you could use all the steering it had- and removed it during the same battery. When I removed it, the car was looser and actually steered less since the dual rate had to be turned down. Two other guys at the tracked were watching and even ran the car a few laps, agreeing with what I saw.
That being said, the F104 diffuser is too small to do anything. They also have to be as low to the track as possible.
Pro10noob is offline
Old 03-14-2011, 12:10 PM
  #4744
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Originally Posted by MikeR
Red dot = 12.5lbs
Thanks Mike.
j.d.roost is offline
Old 03-14-2011, 04:16 PM
  #4745
Trader Rating: 61 (94%+)
here is a list of parts i have that i dont use pm me if u are intersted.
1. f104pro lower and upper deck
2 . f104f60 lower and upper deck
3. f104 ALUM Pivot post
4. plastic rear pod.
5. nip ride f104 rear wheels
6. complete damper
7. 2 spur gears with diff balls both 63tooth
8. 2 stock tplates and 1soft tplate
9. alum high torq servo saver new.
10. 2 full sets of f104 foams. fronts and rears
the chassies will come with standoffs and the side
mounts.
tcb22185 is offline
Old 03-14-2011, 09:07 PM
  #4746
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Default Latest and greatest
How about a McLaren for good measure?
BP SHADOW is offline
Old 03-14-2011, 09:11 PM
  #4747
BP SHADOW's Avatar
Or perhaps an Alonso Ferrari?
Another huge thanks to DISH for making these things pop
Old 03-14-2011, 10:00 PM
  #4748
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
BEAUTIFUL!!
Dan is offline
Old 03-15-2011, 04:21 PM
  #4749
gsxr0311's Avatar
Trader Rating: 19 (100%+)
very nice.
gsxr0311 is offline
Old 03-15-2011, 04:45 PM
  #4750
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default Flat bottom
Will it affect cooling to the motor? Great idea though.
gtfour93 is offline
Old 03-15-2011, 08:14 PM
  #4751
This might have been asked some where is there a offset diffrance between ride and tamiya wheels? right now im running ride fronts(s1) with tamiya rears (soft) and it seems to me my front is wider than the back.
tcb22185 is offline
Old 03-16-2011, 04:43 AM
  #4752
nice.. but the rear wheels on the wrong side??
hansenhon is offline
Old 03-16-2011, 08:36 AM
  #4753
I got my exotek chassis today. Bloody fast shipping!!! Ordered Thursday night and arrives Tuesday morning, gotta be happy with that.
Gotta say a little dissapointed with the quality of the carbon fibre (the cutting isn't as precise as i would have expected for 120 bucks worth) and the instruction manual isn't the best i've seen, but myabe i'm jsut spoilt with tamiya manuals
Anyway my question is. When building the shock, what is the srping used for? Is the spring an option if you want to use it as a main dampner? Also how far in should I thread the bottom ball end on the shock shaft? I don't see it mentioned anywhere. According to the pictures on the website though, thread all the way in?
I got a LOT of sanding and edge gluing to do tomorow Looking forward to seeing how this handles.
LordAnubis is offline
Old 03-16-2011, 09:04 AM
  #4754
Barry White's Avatar
Pics wher probably takin' at the same time as his Bull. He won't make that mistake again..
Barry White is offline
Old 03-16-2011, 09:27 AM
  #4755
BP SHADOW's Avatar
Yes the car was already shot by the time this was identified
If you notice the McLaren is correct.
