The Speed Passion Thread
My Reventon runs ok but is about 1 mph slower than the Tekin R1 Pro I was trying to replace with it. Not sure why. I don't race but my friend and I time our cars once in a while with our radar gun.
That could be many more factors than the speed control.
I kept everything the same and just swapped ESC's. Same motor same gearing same battery same timing. I made sure to turn off the volt cutoff and temp cutoff when testing. Not a huge deal. The Reventon doesn't pass near the amount of current that the tekin does nor do I expect it to at half the price. I was only changing so the programming could be done by a card instead of a laptop.
Hi all,
I'm looking for pc windows software and firmware(s) for SpeedPassion GT2.0 ESC, modified and stock for 1/10 TC racing. As the speedpassion.net web page disappeared, I'm not able to change the firmware. I still have 3 ESCs with old firmwares, , can you provide link or send it to me by email please?
Thanks for any advice ...
Super Moderator
Updated link for the Reventon software
https://www.dropbox.com/s/rbw4vq35l1..._0_25.zip?dl=0
Updated link for the old GT2 software
https://www.dropbox.com/s/80nz03zl3b...20521.exe?dl=0
here it the link
Hi all,
many thanks ...
just looking for good setup for modified racing now, the RPM is very low when comparing to LRP Flow, even I if set the newest mod firmware and maximal "punch" values
Super Moderator
Super Moderator
GT2.0 has a bit different items in setting, was playing with timings and every value at maximum now. Still not as good RPM as LRP Flow, however works good and will see the result on track. Thanks again to all.
Whats a high velocity battery? I see it says that in setup sheet shown? Is that like a battery that takes off after you wreck and battery explodes and launches really far fast?
What is the Digital Racing Response System and what does it do?
Hey all,
today I logged in to www . speedpassion . org (remove spaces) which appears to be the new Speed Passion website (not .net anymore). It has everything from products to firmware packages.
Not sure if this means it is 100% SP, but it seems legitimate.
Crusader
Crusader
Nice. Site looks good.
Super Moderator
wow looks nice! wasnt v1.1.0.25 lastest pc interface version? Seems like a new update is available at www . speedpassion . org/pages/support-and-downloads
found a link to the shop shop . speedpowerrc . com/Combo_c_76.html officiali posted by speed passion on 10th may
