The Speed Passion Thread
I've extended cables due to ease and have not felt a degrade in performance if that's your concern
Trying to find part number for MMM 9.5T-21.5T Rotor hi-torque
technically a motor would run without a sensor cable. I'm just not sure how well.
You need a good hot iron and "pre-tin" before applying it.
Not sure which one you are looking at, but here's a few.
RS13803NA Competition V3.0 9.5T-21.5T Rotor
RS13802 9.5T-21.5T Rotor - Purple ring
http://www.speedpassion.net/en/catagory.asp?c=mtr&sc=30
Thanks a lot!!!!
Hi guys,
Having trouble with an SP Reventon pro 1.1 and 21.5t MMM motor. It runs in reverse when I pull the throttle and if i reverse the direction of the throttle on my TX all it does is move backwards when i brake the car. Is my only option to resolder? I'm using it with a Futaba 3PL TX and I followed the manual instructions where it told me to reverse the direction of the throttle while linking the TX & RX and if I don't reverse it while linking the car doesn't respond to TX at all. \
Thanks in advance!
Thanks in advance!
Hi guys,
Thanks in advance!
Thanks in advance!
A and C wires might be wrong/reversed
Is the RS13803NA Competition V3.0 9.5T-21.5T Rotor a high Torque rotor
Well, somehow I received an RMA from the SpeedPassion.net site that has been allegedly down for 6 months but SP is helping. Hopefully I get my Pro 1.1 back in the mail!
Has there been any news/development/firmware lately? This thread seems dead.
Plenty racing is happening. A lot of the news from races are posted on the Facebook page.
There should be some new developments/news after the holidays
https://www.facebook.com/RC-Speed-Pa...30100/?fref=ts
or from USA distributor Speed Power's Facebook page...
https://www.facebook.com/speedpowerrc/?fref=ts
old reventon pro
Here is my first post on the rctech forum =)
I currently fried my old reventon pro esc, but luckily got hold of a similar reventon pro esc. I say similar because it's not exactly the same, but both are reventon pro's. I did notice small differences between the two. First off the fan mounted on my old esc didn't fit the new esc, the new esc had mounting holes for a larger fan.
Do anybody know if they made changes to the esc during it's production?
First pack testing the esc in my 2wd buggy I instantly noticed a different "hum" from the motor. Also the trigger felt smoother, I really liked that, bud the brakes where weaker compared to my now fried reventon.
I tried the stock v20 firmware (the one focused on brakes), it did do some good things but it had cogging at low rpm's.
I then read on petitrc that the much more fleta 4 firmware would be better, tried that aswell but stil had low speed cogging and even spikes in rpm in midrange rpm's.
I would like you to share your experience with firmwares on this esc.
Any recommendation wold be appreciated.
Also why would there be such differences in performance for the brakes? Different fet's maybe?
HI,
I just bought a Reventon Pro EX 1.1 to run in my Pro10 (2S, boosted 10.5T). Can someone please recommend a starting point for software and settings? I've tried reading about the Stock1 and Mod1 options, but I must admit I'm a bit confused. I normally run Hobbywing.
Thanks, Scott
Thanks, Scott
Anyone know what's up with the Speed Power website? I tried to order some stuff during their BF sale and couldn't because the store was down for upgrades. I checked tonight and its still like that. Kinda makes it hard to support SP...
it's working now and the Black Friday code is valid for another week
