The Speed Passion Thread
Well I bought one anyway.
Great motor, very strong bottom and top end. Brakes are good too.
Ended up running more boost and more aggressive punch settings to get the bottom end feel I like, 30 Deg motor timing and still it came off at less than 60 deg after a 5 minute run.
Happy days
Happy days
The V4 13.5s have been running great. They are also officially ROAR approved now. I know this is the onroad thread, but Michal Orlowski just won the 4WD Euros running a v4.0 motor.
Forgive me if this has been answered, -but I haven't found the answer (yet I am sure its been posted in the 862 pages of this thread ...I just haven't found it).
I just removed a revtech 21.5t motor and swapped w/ a SP "MMM" 21.5t.
The MMM I have is set to +10 timing, ...the instructions are vague, ...how do I adjust the timing on this motor? I think, but am not clear, that I have to purchase a new sensor board?? Where does one get said sensor board? ..this is in a Tamiya Mini, gearing is fixed so real options are to adjust motor timing. I had the Revtech Killshot in there and it was a good motor, but our top driver w/ the SP MMM was passing me on the long straights.
Also, are there options to switch the stator on that motor? What is recommended for higher RPM?
Hello, I have a Reventon R that won't calibrate. This happened after trying to change the firmware to stock 0. It worked fine in mod 0. The program card won't show any of the settings. I never was able to download the stock 0 successfully. The Reventon program won't connect with the speed control. I'm wondering if there's a way to do a hard reset? Right now the speed control won't do anything. Any help would be greatly appreciated.
Find out what sensor the quick guy is running and copy him
The standard black sensor board is actually at about 38-40 deg when set at +10 position, the only way to get higher is to purchase one of the optional sensor boards, which are red +10, green +20, yellow +30 or blue +40.
I wonder if in the next firmware update, they could write in some code for direct application. I have been on the hunt for a cable that might allow for direct connection from my tablet and the ESC. (Namely because I don't really want to have to buy the BT adapter. For me, I would rather connect direct using my Tablet or smartphone (Android) to connect direct to the box and make changes. I found a proper cable that accomplishes this.
http://www.amazon.com/gp/aw/d/B00MWQ...C0L&ref=plSrch
How many of you are using the BT adapter? would anyone prefer a cable option?
Momo
Momo
My guess is he is running at least a yellow +30. Some rules don't allow for changing of anything except the timing board so you need to be clear if they allow for rotors too.
I do know that our fastest driver did switch out the sensor boards, -he told me so.
Also, this does confirm that you must purchase sensor boards to adjust the timing (this is different than any motor I've used in the past ...and wanted to confirm).
Thanks!!
One more question,
I have the SP 21.5T "MMM" motor. It states that timing can be up to +20 degrees. So I am correct in assuming that the yellow sensor board which is +30degrees would not work for my motor? ...I am thinking that the green sensor board which is rated at +20 degrees would be the highest I could go? ...but maybe not?
(I wish the SP website were more clear on this)!
One more question,
Bricked Smart LCD Program Card
I tried to update the firmware my Reventon Smart LCD Program Card from 2.4 to 2.7. Nothing happend after 20 min, so I disconnected and now the card seems to be dead. Any suggestions?
you can install any of the sensor boards, the plus +20 on the endbell isn't an actual 20 deg. I haven't put one of the option sensors on my motor checker, but my guess they are just incremental advances to go above 40 deg actual timing of the black sensor board.
super helpful.
I recent;y purchased a wifi module. But I can't seem to find the app for it. Any suggestions?
