The Speed Passion Thread
I bought a reventon stock ESC and cannot find a program box for the thing, everyone seems to be sold out and is on back order. Anyone have an extra?
Hi,
I just bought a 21.5r ver.3 that will be installed in a onroad touring car, what is the maximum safe temperature to run these motors at?
Thanx in advance.
Thanx in advance.
Trader Rating: 32 (100%+)
So keep in the ball park of 70 to 80 degrees Celsius, am I better of temping of the can or temping of the end of the rotor if possible?
If I temp of the rotor should I be aiming for a lower temp?
Just solder it up to a justock and used 6000mah turnigy lipo and it seems quite a potent little motor, good value for money.
Take the temp off the side of the can if you can see the stator take it off that because thats what will fail when it gets above 180F. You will melt off the varnish on the windings and then it just melts down into goo.
Once again Kevin thanx, very much appreciated.
Also....I think the general should know about the "$30 POWER FAN"........it is a must have to the motor right now for all TC racing.
Bingo....but they don't have that yellow wire no more. Just power that directly from the power terminal of your ESC. It is a MUST HAVE for any serious TC racing.
nice, where did you order that from ?
