The Speed Passion Thread >
Like Tree57Likes
Old 06-10-2013 | 09:09 PM
  #11686
Originally Posted by ^jynx^
Your right it is the S. but either way the brakes suck out of the box. I'm assuming I need the card to adjust it?
Buy a LCD card or wireless module for change setting. Set brake force to 70-80%. The default setting of Reventon S is 30%.
WMGary is offline
Old 06-10-2013 | 09:19 PM
  #11687
Originally Posted by Cale79
As i wrote i had the same problem. As i now tryed to start the program as administrator it worked flawless. So try that
I updated the esc with stock1. The programbox with 2.7. At the track i had the problem my esc didnt do anything anymore. So make sure u test it. The esc didnt want to start up anymore. After putting the 2.4firmware into the programbox it worked fine again. All setting also the hybribboost work great.
This esc is a monster !
If you are doing the other process (for example open the browser) when you updating the program card, the progress bar will be freezed. But it does not affect the firmware update. The update progress is around 6 to 10 mins.
Do you have update the ESC firmware again after update the program card to V2.4? The stock1 firmware is V20?
WMGary is offline
Old 06-10-2013 | 09:25 PM
  #11688
Originally Posted by Chrisg23
Ok, I'm about to install a reventon pro in my 17.5 tc. And have a few questions;
1) how to I install the 'stock 0' blinks mode software onto the esc?
2) will I have compatibility issues with the Novak 17.5 motor?
Download Reventon PC program from Speed Passion website. File name is "Reventon PC Program with USB Driver V1.1.0.22".
Download link: http://www.speedpassion.net/en/download.asp
Video link: http://www.speedpassion.net/en/video.asp?c=2
Follow the video instruction to install the PC program and update ESC firmware.
Reventon Pro should be work on Novak 17.5 motor. If the ESC is stop suddenly when running, refer speed passion website about motor temperature problem. http://www.speedpassion.net/files/So...eventonPro.pdf
WMGary is offline
Old 06-10-2013 | 10:09 PM
  #11689
Ran my Reventon Pro Over the weekend in modified Touring Car.
My car did some of the quickest laps with Stock1 V20 firmware w/4.5t, No problems.......ESC ran awesome! Thanks Albert!!!
Sean Williams is offline
Old 06-11-2013 | 03:01 AM
  #11690
Default Reventon Pro
I updated my Reventon Pro to the latest Fleta 4 stock1 software and now cannot do any settings via the speed passion program box, only via the pc interface on the fleta software. I tried to revert back to the speed passion software but it does not support the files installed on the esc.
Any ideas how to flash the esc to speed passion software as I would like to do setup changes via program box at the track.
2Quick is offline
Old 06-11-2013 | 11:26 AM
  #11691
Thats nive Sean, can you send the setup? What motor you use?
Thxs in advance.
kavajas is offline
Old 06-11-2013 | 11:30 AM
  #11692
Hi there, you have to put the Fleta softwear at Reventon box.
http://imageshack.us/a/img849/5051/cimg0228j.jpg
Regards,
kavajas is offline
Old 06-11-2013 | 01:48 PM
  #11693
WMGary, thanks!
Chrisg23 is offline
Old 06-11-2013 | 01:57 PM
  #11694
Regards,
Thanx for responding.
Can you explain how to update box to fleta software ?
I tried to update the box via the fleta software as per the manual by pressing the reset button while attaching the usb cable to pc. The screen opens with no option to update firmware..
2Quick is offline
Old 06-11-2013 | 04:57 PM
  #11695
ok so I ordered the LED Program Card. I dont race, just bash with some friends so I didnt feel like I needed any thing fancy. It should be here tomorrow. Is there anything I need to know or is it pretty user friendly?
^jynx^ is offline
Old 06-11-2013 | 06:21 PM
  #11696
Easy as mate. It comes with some settting cards ( stickers ) with the settings your after.
Yogi- is offline
Old 06-12-2013 | 08:05 AM
  #11697
I too have the same problem. Can anyone help. Thank you.
Chris kal is offline
Old 06-12-2013 | 01:27 PM
  #11698
You have to go to MuchMore Fleta /assets folder and copy all the files to Reventon 1.1.0/assets folder. Then open Reventon Program, connected the box clicking the bottom them chose 1.4 from MuchMore.
kavajas is offline
Old 06-12-2013 | 03:10 PM
  #11699
got the LCD card. Updated firmware and now I'm all set!
^jynx^ is offline
Old 06-12-2013 | 03:44 PM
  #11700
Some times wen i turn Reventon box gives me this error:
CHECK SUM P:4AEE
F:CC4D ID:1A0000
Any teck help????
Thxs
kavajas is offline
