The Speed Passion Thread
Super Moderator
You are welcome.
I came with this set up for 10.5 should worked very well with the 13.5 but didn't get to try it ran out of tires to try the 17.5 lol.
Don't know if this will be the final version but it has great power with the 10.5, my car was actually lifting the front wheels of the ground a couple of times.
Super Moderator
I didn't get to try different sensor boards I tested them with the stock sensor board.
got the gt 2.0.bad switch from the box.1 month+ finally used switch from cirtix(support here in ill. so good)wired it in now switch doesnt work at all and powers up only when i hold the setup button down.any ideas
You are saying the switch that was included with your GT 2.0 was bad when it was new? Then you installed a on/off switch you took from a Cirtix you had onto the GT 2.0?
i bought it off a guy who won it in the raffle at the roar nationals,so theres no receipt. ive been unable to get help locally so i though i would try the switch from my blown cirtix
Please give our office a call and we will take care of your swtich...Phone 1-888-928-1328.
anyone used a GT2.0 pro in a WGT 2S lipo and a 17.5 motor that care to share a set up ???
i have the feeling i can either have good torque or good top speed but not both
Thanks Phil
Thanks Phil
Any updates on when the Reventon EX Pro will be available?
And is there any news on how the testing went with the software that'll support 13.5-21.5?
As above...
What USB cable do you need/use for the computer fir the esc?
