The Speed Passion Thread
#9950
I had this problem and it turned out to be an incompatability between the ESC and the Novak Ballistic motor. I found a lot of threads on problems between Speed Passion speed controls and Novak motors. I had tried changing sensor wire, timing board on the motor and resetting the ESC., nothing worked. The whole time my HPI Flux motor was fine.
What motor are you using?
#9951
This is on the NEW LED box that came with the reventon correct? If that is the case update it through your computer twice, When I updated mine, The first time it said complete but when I tried to use it on the esc nothing worked, Updated it again on the computer and all was good. If your not using the new LED box that came with the reventon, there might be compatibility issues with HW stuff or even the LCD version as the Reventon is all new..
#9952
#9954
Reventon boost software is being tweaked still. It will be worth the wait! The sofware is unique for the new speed control so you will not be able to use HW
#9957
I will forward trickedout's suggestion of updating the LED box twice to him to try that if he doesn't read this thread before the weekend. I know the HW stuff does the same things at times, curse of those electronic gremlins.
Cheers
Rob.
#9958
i have just recieved the reventon pro, comes with a nice LCD box, and i also have the BT adaptor. this is all nice, speedy looks the goods, but its quite useless to me with no boost software. i really hope its coming very soon, basic settings are just too slow for my track.
#9959
tried it 3 times now even while standing on one foot
The issue that JAM racing is having is that after setting the Reventon esc into 0 timing mode using the NEW SP LED box (not lcd) as a PC interface, it will not work and allow him to make changes via the LED box afterwards.
Cheers
Rob.
Cheers
Rob.
#9960
Make sure you download the LATEST software from sp website as they updated it as of 9-7-12 and then make sure you update the LED card by holding the reset button while opening the SP software on your computer, On the left hand side will be an update button and should show the V1.3 option, update it twice and it should be good. I have my Reventon R and updated my LED card to V1.3 and now have my esc in Stock0 and can still adjust everything from my LED card.
