The Speed Passion Thread >
Like Tree57Likes
Old 07-24-2012, 10:28 AM
  #9721
Trader Rating: 17 (100%+)
Originally Posted by JAM Racing
does the revention esc have Roar approval and if so when will it be listed
I asked the same to ROAR, and they said there are 40-50 ESC are waiting for approval before ours....and that was like 2-3 months ago.
Solara is offline
Old 07-24-2012, 01:43 PM
  #9722
JAM Racing's Avatar
Default thanks for the reply
does seem a bit odd though...hw v3 came out after reventon and is alreadyy aproved acording to their forum
I know the product has the market appeal but without this endorsement its not going to get it market share
YES i thought some KPI might wake up marketing
all the best
JAM Racing is offline
Old 07-24-2012, 09:51 PM
  #9723
mes
Maybe approval is pending due to some software issues. When I wanted to order the Reventon R around here, I was asked to wait a little or go for the GT2.0 Pro instead.
Will there be a bug fix soon? Running a non-boosted 13.5 in my B-Max2 is starting to get boring, and I really want another SP ESC. However, I've started contemplating other ESCs, too...
Is the Cirtix Stock capable of handling a 6.5 Turn for about 7 Minutes in a 2WD/4WD buggy with enabled overheat protection? That might be an interim solution...
mes is offline
Old 07-25-2012, 04:50 AM
  #9724
hotrod1933's Avatar
Default blinky
help
gt2 pro (going from memory) and have got 508 loaded and card confirms this but no red blink ??
am i doing something wrong or is led just stuffed or is it hard to see underneath.
other car set the same is ok
can get away with for club stuff but maybe not for higher events.
hotrod1933 is offline
Old 07-25-2012, 08:23 AM
  #9725
all the best
The other way to say is...the STOCK0 (blinky) software that we are going to use on REVENTON series ESC, we have to have ALL of the ESC available to sell publicly in order for them to list it. We are selling the REVENTON S, but not the R and the REVENTON PRO....and that might be the reason.
But I don't know why they are not simply list the STOCK0 software with Reventon S ESC only for now....it must be their system that I don't really know.
Solara is offline
Old 07-25-2012, 08:25 AM
  #9726
Boost software is testing right now...mainly need to test with MOD motor, then with stock motor, without blowing up the ESC.
Don't bother about running that setup on Cirtix, it won't work....
Solara is offline
Old 07-25-2012, 08:26 AM
  #9727
Originally Posted by hotrod1933
help
After loading the software onto the ESC, you must TURN OFF everything (radio and esc) and turn back on, and do the calibration with radio, then turn everything off again...then turn back on.
That happened to alot of the ppl....for the new ESC, after calibrate, it will turn off by itself.
Solara is offline
Old 07-25-2012, 09:59 AM
  #9728
mes
Thanks for the quick reply! I'll probably get a 9.5 turn in this case...
mes is offline
Old 07-26-2012, 02:32 AM
  #9729
JAM Racing's Avatar
Default i need the R
here in aus the nature of the tracks require the r as i generally run 21.5 blinky
bigger tracks id run stock to avoid going to sleep during a race as the straights go on forever so i need one that can do both
stock overhere runs timing and boost in the 17.5 class
The products looksa ver cool
thanks for your reply
Old 07-26-2012, 04:30 AM
  #9730
hotrod1933's Avatar
Default blinky
help
tried that but still no led at all.
makes all the beep beep when setting endpoints but no led must be dead led
Old 07-26-2012, 08:17 AM
  #9731
help
If you have no LED at all, then the LED must be dead.....
Solara is offline
Old 07-26-2012, 12:20 PM
  #9732
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Thanks howard ! Can't wait to get my motor and start turning some laps
Marcos.J is offline
Old 07-26-2012, 12:46 PM
  #9733
Welcome back to ON ROAD....and anytime...
Solara is offline
Old 07-26-2012, 12:58 PM
  #9734
help
Double check your throttle trim is at 0, I have seen a couple time that the radio hd throttle trim and no "blinky led".
ercwhtsd is offline
Old 07-26-2012, 01:07 PM
  #9735
Thanks ERIC....
Solara is offline
