The Speed Passion Thread
#8836
My understanding is that to get the wireless option you have to now purchase the wireless module is this correct and how much will this box cost us now? I guess the good thing is if you don't want the wireless option then you still get the box to make changes and do software upgrades included instead of having to purchase that separately like before.
I am interested but I would like to know total costs upfront instead of being blind sided like with the product this is replacing.
Remember, the Wifi/Bluetooth module are totally OPTIONAL. They are around $40 (I am really guessing it here...) Wifi (APPLE) is alittle bit more expensive then the bluetooth (android) because APPLE do need to charge everyone more because it is APPLE related.
But if being wireless is not something you have to have...the included LED box with USB connector will get you setup, upload firmware ready, without paying any extra.
Only unit that does not come with the box is still the REVENTON STOCK CLUB RACE.....but this time, the parameter can be adjusted via the ESC on board button. The LED box will be optional. Good to have it because the new software (blinky) will have 7 options to adjust....also the LED box will give you the LIPO voltage reading, the ESC temperature reading as well as the firmware inside your ESC reading (On Reventon Stock Club Race it will only read ST0 = Stock "0" software because that unit cannot be software adjustable.)
#8837
Tech Legend
Yes, eventually....once the Turbo/boost software released (will be after the release of the ESC because we are still in the testing phase now), you will be able to use it and adjust all the parameter just like the current GT series. Only, BETTER....
Remember, even the Reventon S series can have benefit of the future boost software. Talk about the low-budget boost unit for fast club race.
#8839
Hobbywing http://hobbywing.com
ZTW http://en.ztwoem.com/
#8840
Because GT series come from hobbywing and REVENTON from ZTW.
#8841
Surely it's at least 50% right? It's common knowledge the sp gt series is oem hobbywing.
#8842
I'm running a 17.5 V3.0r motor in my 4wd sedan and have a question on bearing lube/oil. I recently took the motor apart for a cleaning and I flushed the bearings out with motor spray. The front bearing (pinion end) seemed to have blue grease iwhich has now been totally flushed out.
What is the best oil or lube for these bearings? I've seen the lube by Scorpion for their BL motors and can pick up a bottle if that's good enough. What are you using?
#8848
Just want to let you know that the link for the "Reventon PC Software V1.0.3 with USB Drive" is dead on your web site...
#8849
