The Speed Passion Thread >
Like Tree57Likes
Old 07-25-2011 | 01:31 AM
  #7531
StevenOlsen's Avatar
Originally Posted by hpipurple
Hey,
Has anyone found that running 323 stock software in MOD is terrible??? Its got wild top speed, but the driveablility is %^&* to say the least???
Whats the secret with running 323 in MOD and making the driveability work???
Thanks in advance
try my setup really happy with it but has a bit to much power with a 4.5
Attached Thumbnails The Speed Passion Thread-start-setup-med-sp-regulator..png
StevenOlsen is offline
Old 07-25-2011 | 04:08 AM
  #7532
CraigM's Avatar
Hmm I ran exactly these settings yesterday (sourced elsewhere) with a 4.0 and I had no top end whatsoever, I ended up going back to 528 mod and had heaps more power, thinking now that maybe the settings didn't send to the ESC properly. The track I was running on had a 62m straight
CraigM is offline
Old 07-25-2011 | 04:51 AM
  #7533
that funny, had the same experience with both a 4.0 and a 5.0 the 4.5 feels like it has more top speed, like the 4.0 and 5.0 dont respond very well with timing.
did you also had problems with the motor overheating ?
Old 07-25-2011 | 08:32 AM
  #7534
g12314's Avatar
Hey,
Thanks in advance
Two weeks ago I ran a 7.5 1S V3 using a GT2.0 LPF with 323 stock firmware on our local big track (225ft straight). Car was very easy to drive as the bottom end was "soft" enough for easy control (I usually run 17.5) and the top speed was on pace with a 4.5 running non-boosted firmware. Motor temps were a max of 170F with track temps of 135F.
Another racer was running a boosted 4.5 and I must say it made my car look like it was standing still at the end of the straight. Crazy fast, but harder to control. Here is a link to round 1 qualifying: http://www.youtube.com/watch?v=sHp3L...eature=related
Yellow car is me, Pink car is the boosted 4.5. I was 2 teeth undergeared here, so the speed at the end of the straight was a bit slower than the later rounds.
g12314 is offline
Old 07-25-2011 | 12:35 PM
  #7535
This is directly taken from my speedo that still has the mod settingds from Toni reinhard
1 Mode for/brake
2 Drag brake 0
3 volt protection 3.0v/cell
4 DRRS Punch LVL 2
5 Brake force 62.5%
6 Reverse force 25%
7 Initial brake 0%
8 Neutral range 6%
9 Boost timing 35%
10 Turbo Slope 6
11 Overheat protection OFF
12 Turbo Timing 20
13 Start RPM 15,000
14 Turbo Delay 0.2sec
15 Timing ACC 650
This is what i think i Emailed to you and with gearing of 8.0 i was so fast it was almost uncontrollable , and SO fast on the straight , i actually didn't drive mod in ETS , because i was snapping belts and not braking enough at then end of the straight and crashing A LOT this is why i am suprised you have no top speed , try a 4.5 and see what you have meybe 4.0 and 5.0's dont like too much timing
sidecarphil1 is offline
Old 07-25-2011 | 01:23 PM
  #7536
I can assure both JIMMY and PHIl's setup with 323stock and MOD are PLENTY FAST and drivable as I used both setup and drove at a 1/8th track and the car is the fastest thing ever that I drove (compare to 4.5 no boost and I was using boost 6.5).
However, our track is prepped for 1/8th NITRO on road race that day so traction is top notch....almost impossible to have anything that is not controllable. I have seen a lot of ppl understeer, but have not seen anyone that is oversteer except me.........on the same video, my car broke only in like 35 seconds by using 323stock and 6.5, it sheered off my front CVD into 20 differnet pieces and I was driving 3WD that caused my car undrivable...
way too much power...but I LIKE IT very much. We are planning to do that again in 3 weeks and will run with Paul Lemuiex running SP GT2.0 PRO ESC with Thunderpower 4.5T.
Solara is offline
Old 07-26-2011 | 08:08 AM
  #7537
defcone's Avatar
Just ran the sp2.0 paired with a v3 4t, and it felt like 90% of the power was within 50%-60% of the throttle range. Is this normal? Ran with 205_MOD, default settings 7.9fdr.
defcone is offline
Old 07-26-2011 | 10:47 AM
  #7538
I think you are running sensorless mode...can you remove the sensor wire and see it ran the same...?
I am not exactly sure what you mean 90% of the power was within 50%-60% of the throttle range....like it is in 2-speeding? It might have to do with the DRRS setting...what is your DRRS at?
Solara is offline
Old 07-26-2011 | 10:06 PM
  #7539
defcone's Avatar
Drrs was at seven yeah it felt like it was two speeding.
defcone is offline
Old 07-27-2011 | 12:30 AM
  #7540
Suspended
whats difference of sp gt v2.0 and v2.1? do they have same performance? whats lowest turn of motor for both ecs?
littlealex is offline
Old 07-27-2011 | 01:39 AM
  #7541
mattwoodcraft's Avatar
Originally Posted by Pattojnr
yes ill be there. lots more testing to do yet
hi
what FDR are you using with the 3.5 ? i have programmed it with 119 mod software same as you have now can you give me a starting point on what settings i should be running at west coast
thanks
mattwoodcraft is offline
Old 07-27-2011 | 01:40 AM
  #7542
CraigM's Avatar
No the motor was stone cold
I don't think there's any problem with running 4.0 with boost, when I put 528 it felt like it had a lot more boost so I think the settings or software didn't take properly when I first loaded 323. I'll give it another go this weekend and let you know how I go, cheers
CraigM is offline
Old 07-27-2011 | 05:08 AM
  #7543
Pattojnr's Avatar
Originally Posted by mattwoodcraft
hi
thanks
still trying things but seems so far, 8.8 is a good start.
Pattojnr is offline
Old 07-27-2011 | 05:14 AM
  #7544
befor the down poor of rain here i took my car for spin and it is stupid fast which i really like i so look forward to sunday hope the weather clears by then..
what are the differences in the rotor sizes 12.5mm vs 13mm
Old 07-27-2011 | 05:44 AM
  #7545
Pattojnr's Avatar
havent changed the rotor , its out of the box. but will start playing soon.
Pattojnr is offline
