The Speed Passion Thread >
Like Tree57Likes
Old 07-12-2011, 10:46 PM
  #7456
TeamWTF's Avatar
Originally Posted by bertrandsv87
With the driver stand in the middle of the 280 meter long track , you will not be able to see the end of each side 140 meters away ! Take you tape and re-measure the track, buddy !!! Even a 280 foot track is too big for 8scales !!!! Any track above 250 feet long is not practical !!! Get your facts straight !!!
He is talking lap distance, not distance from end to end
ie, 280m is how far the car would travel per lap
TeamWTF is offline
Old 07-12-2011, 11:42 PM
  #7457
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by OVA
Needs help No blinky led
I have the SP GT pro 2.0 esc and I don't see the led light anywhere on the esc..even on the switches..there's a red buttom but no led
the esc is carbon black with purple top heat sink..
Its on the bottom of the case
defcone is offline
Old 07-12-2011, 11:59 PM
  #7458
mr fit's Avatar
Originally Posted by rendcool
folks, what's the good speed passion esc for stock 17.5 tc ?? I use epic D3 for the motor.
and is it competitive enough with other esc out there like lrp, tekin, etc ??
you can use the prostock (comes in black or blue) and the 323 program. this esc is made for boosted 17.5 class. the gt2.0 works just as good too.
mr fit is offline
Old 07-13-2011, 02:26 AM
  #7459
Holmenkollen's Avatar
Yes, I race at the same track. The straight is around 262 feet long (80 meters).
Holmenkollen is offline
Old 07-13-2011, 02:48 AM
  #7460
RevMaxx's Avatar
Originally Posted by Solara
Yes.....overall at ETS, top driver using 323stock with 4.5 motor. But that is only for professional and they have alot of motor/esc for spare. But yes, 323stock can work with 10.5...upgrade that now.
Hi Solara, with the 4.5T motor, do you happen to know how much timing and boost their set-up had with corresponding FDR?
t-i-a
RevMaxx is offline
Old 07-13-2011, 05:07 AM
  #7461
Yes thx. I dont see te problem in how i wrote the question. "track is 280 meter long" , not 280 meter side too side.
MarcusEngdahl is offline
Old 07-13-2011, 07:43 AM
  #7462
Trader Rating: 17 (100%+)
I do get what he meant at the end...he meant 280 meter full track length...just communication problem, all good...
Solara is offline
Old 07-13-2011, 07:46 AM
  #7463
t-i-a
8.4 final, 25 boost, 20 SC....but it is on 4.0T
Solara is offline
Old 07-13-2011, 07:48 AM
  #7464
I answered your question on last page already, but I will post again..
Safe way to run 5.5T mod is run 205G, full timing, gear around 7.5 or even higher (depends on motor temp)...motor timing in middle position.
Solara is offline
Old 07-13-2011, 07:54 AM
  #7465
Tnx for the answer! if i have understand it right 205G software is installed as standard in my new gt 2.0 pro?
Old 07-13-2011, 08:07 AM
  #7466
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Bottom..?? the bottom is all black plastic cover, it is suppose to blinky thur the black plastic case ?
OVA is offline
Old 07-13-2011, 09:21 AM
  #7467
Yes...205g is the pre-installed software for GT2 PRO.
Solara is offline
Old 07-13-2011, 09:24 AM
  #7468
OK...your ESC is probably 2+ years old. Contact Speed Passion USA and let him know you have the old lower case, we have the smoke clear version of the GT2 Pro bottom case for you with the ESC decal....just pay shipping and he will take care of that for you. With that bottom case, you will see the red LED blinking light from the bottom/side.
Solara is offline
Old 07-13-2011, 10:09 AM
  #7469
skypilot's Avatar
Trader Rating: 14 (100%+)
Response?
Originally Posted by skypilot
I've been racking my brain trying to help a friend with a silver arrow esc and 5.5 motor combo.
after reading just about everything i can find this is what I have come to understand and need carification.
running this system on 2s will not work, "If using 2 cells lipo powered vehicle, please use our GT2.0 Pro series ESC."
running this system on 4s will not work "Support up to 4 cell lipo with 3000KV motor." the SP 5.5 SCT motor is 3905kv
"Silver Arrow II ESC is best to be used on 3 or 4 cells lipo power"
so the only way to run the esc/motor combo as sold is with 3s, I'm assuming this as I don't have a 3s lipo to test with.
So I'm also gonna assume that if I install a GT2.0 esc and this 5.5 SCT motor on 2.s it will be ok.
at this point the esc is useless unless he buys a smaller motor, which I already know hes not going to do. can I send it in for credit towards another Pro 2.0 esc? you guys are pretty much giving them away on the web site so trying to sell it is mute.
edit, ok so i wired up a pro 2.0 (on 2s) to the motor and apparently its hurt, no rpm whats so ever and after a couple of trigger pulls the red and green lights flash on the esc. (it also did this with the silver arrow esc and 4s)
skypilot is offline
Old 07-13-2011, 01:07 PM
  #7470
Response?
Contact the USA office and submit the RMA...if the motor or ESC are within the warranty period, we will replace it...we have the trade in program that our office can work that out with you.
Solara is offline
