The Speed Passion Thread
#6541
I'm trying to learn how to use the progran card that came with my GT2.1 EX. The instructions say the plug is in the lower right corner. Well it isn't. Mine has 2 plugs located in the middle of the right side. The instructions say the plug is marked for + - and signal. Neither of my sockets is marked in any way. Which socket do I use, and what is the polarity? Your instruction sheet is rather poor in regards to the program card.
If you are looking at the box and the ports are the top edge the pins are:
Left Plug
Right plug
- + <signal>
Right plug is used to connect to the ESC.
#6542
I posted this in the Electronics thread but maybe it would be better here...
Hello,
I'm a newbie to the R/C World. I just bought a second hand car and was looking at the wiring.
It has a Speed Passion GT 2.1 Pro Stock ESC. There is a capacitor on it.
The one thing I noticed straight away is that the capacitor has both the Black and Red wires soldered to the RED + on the ESC.
Now from my limited knowledge of capacitors I figured the guy who sold it to me had done it incorrect and it should be on the Positive and Negative of the ESC
I looked in the manual and there is a picture showing how to connect it but it has arrows pointing to the capacitor wires and says -
Red Capacitor Wire (Positive). Black Capacitor Wire (Positive)
The picture does show that the black should connect to the negative but it is not overly clear and if you were not sure and followed the text pointing to the Black wire saying "Positive" I can see how people would connect it to the Red.
I've just had a good look and there is a Note which does say
NOTE: The Capacitor MUST be connected to the (+) and (-) of the ESC. The ESC WILL be damaged if it is operated
without the capacitor.
I think there would be a number of people (like the guy I bought this from) who would just look at the picture and wire it incorrectly.
(you can see a PDF of the User Manual on the Speed Passion web site.
I included a screenshot from the manual showing the problem but don't have enough posts yet to post URLs)
The note says it WILL cause damage if operated without the capacitor. With both wires on the Positive it is effectively operating without the capacitor..
Despite the "Note" everything does seem to work ok.
Anyone else noticed this.?
Is it likely to have caused any long term damage ?
Would be interested to hear peoples thoughts.
Leigh
Hello,
Leigh
#6543
Hello,
Leigh
Hello,
Leigh
hope this help and hope you enjoy this hobby as much as i do
#6544
#6545
Just got home from a long day of racing and I would like to say I am very impressed with my newly installed GT Pro Stock V2.1 speedo. Im running it in my Team Associated SC10 in stock short course class with a Trinity Dou 3 17.5 motor. Im running 26 pinion and 75 spur and max. timing and boost. Motor temp. borderline too high at 160 after 5 min. race but the power was smooth and unreal for a stock motor. Very good speedo, highly recommend.
#6546
Boost
I have just had the chance to run my speedpassion gt2 with the new 119 firmware on it. All I can say is wow is it great. I run a tekin in one car and the speedpassion in another car. Both run 13.5 motors and the speedpassion is faster and easier to setup and understand. It was worth the wait to get this kind of performance and tunability.
#6547
Hello everyone,
I have been trying to understand how the hell updating a firmware works...
When i go on the speedpassion website, then on GT2.0 LPF ( my esc ), and when I look for a firmware, it comes up with " drivers " , " programs " and " firmware " ....
What am i suposed to dowload on the PC and then which one for the ESC o.O
Im confused lol ...
Btw, i run 13.5 and I want to have the boost/supercharger/turbo updates...
If someone could take abit of time and do a explanation on how and what to download with links, it would be much much apreciated
Thanks in advance
Im confused lol ...
Thanks in advance
#6548
Hello everyone,
Im confused lol ...
Thanks in advance
Im confused lol ...
Thanks in advance
http://www.speedpassion.net/us/produ...02PROscb&c=ESC
Found the video, the last one:
http://www.speedpassion.net/us/video.asp
Install the firmware twice to make sure it takes completely. Then redo the one touch set up, calibrate the esc to your radio endpoints. Then turn the throttle endpoint up on your radio some, to make sure any radio drift doesn't prevent getting full boost.
#6551
#6553
hi all
i want to change my capacitor i've got 2200 25v, will it be ok with my GT 2.1
cheers Ginge
cheers Ginge
#6554
I have a GT 2.0 lpf in my blitz with a Nemesis 10.5, and noticed that when I give it full throttle, while I'm holding the truck in the air, that it will run at partial throttle for about half a second then go to full. Is that normal? Also a couple weeks ago I had the issue that after two or three minutes, the truck would be sluggish when moving from a dead stop, or a really slow section. I thought it may be the motor so i tried a ballistic 10.5 and it still did it. Would really love some help at this point.
#6555
