The Speed Passion Thread >
Like Tree57Likes
Old 07-26-2009 | 03:34 PM
  #436
Originally Posted by Govert
Thanks Razzor,
very helpfull information! I'll try to make a pic later this day and post it here.
Hi govert, Where in the Netherlands are you from. If you live close I can come and check out the motor to check it for any problems. You can send me a PM about it.
Rick Thomson is offline
Old 07-26-2009 | 03:35 PM
  #437
Hi guys,
In order to make sure I'm going to buy the right rotor, could someone please tell me what the difference is between these rotors:
SP High RPM competition rotor for 4.5T
PN#RB13845
OR
SP Pro racing rotor for brushless 4.5T
PN#RA13845
Thank you in advance guys.
Govert
Depends on the all sorts of things, personally I prefer the 12.5 mm rotor over the 13.
Old 07-28-2009 | 06:24 AM
  #438
Redwood's Avatar
Hi guys I have a quick question.
I just bought a 6.5T LRP X11 motor and wondered where to start with the timing and gearing. I will be using the Speed Passion GT 2.0 and the track is medium size.
A conservative start point would be great, since I can gear up from there without toasting the motor.
Thanks in advance
Neal
Redwood is offline
Old 07-28-2009 | 07:02 AM
  #439
bluephi1914's Avatar
Originally Posted by Rojna
Actually I find the LCD much simpler then the program box, its smaller, much better quality, and makes programing easier by displaying everyting on the back lit LCD ... especialy at night or indoors
+1
I think that the LCD allows you to manipulate the ESC more than the box does. I dont even use my boxes anymore. LCD and.or computer
bluephi1914 is offline
Old 07-28-2009 | 07:05 AM
  #440
Originally Posted by dameetz
Anybody?
I think it determines how much or how little space you have before your car moves when pulling the trigger on your remote. depending on where its set, you either pull a little and your car goes or you pull a lot and then your car goes.
I used to have mine set at 6, but i have a heavy trigger finger and the car was a little to sensitive... so i inscreased it.
Old 07-30-2009 | 10:28 AM
  #441
joelwhite's Avatar
A question for the masters. Id like to add capictors to my LPF v2.0 for the added braking and such.Do I need the speedpassion one or are there other options that work.Thanks in advance!
joelwhite is offline
Old 07-30-2009 | 11:12 AM
  #442
syndr0me's Avatar
Do want!
Attached Thumbnails The Speed Passion Thread-thurs-speedpassioncomp3-1.jpg   The Speed Passion Thread-thurs-speedpassioncomp3-2.jpg   The Speed Passion Thread-thurs-speedpassioncomp3-3.jpg
syndr0me is offline
Old 07-30-2009 | 09:39 PM
  #443
BlackedOutREVO's Avatar
R/C Tech Elite Member
Originally Posted by syndr0me
Do want!
Those are pretty sick!
BlackedOutREVO is offline
Old 07-30-2009 | 09:43 PM
  #444
Owen RaCing's Avatar
If only it was black..
Owen RaCing is offline
Old 07-30-2009 | 10:49 PM
  #445
Airflow's Avatar
Do want!
How come the advance timing of this motor is clockwise and
not counterclockwise like other brushless motor?
Airflow is offline
Old 07-31-2009 | 01:53 PM
  #446
You will find that the 10 Deg mark pushed against the sensor housing is 10 Deg, which is anti clockwise.
bjspinner is offline
Old 07-31-2009 | 02:50 PM
  #447
cosmo1974's Avatar
Exclamation
I'd appreciate some more feedback on the functon of the capacitor and especially its relationship to braking.
One function of the capacitor will be to low pass filter and remove some of the higher switching artefacts. In this usage, adding more capacitance past a certain point, will not add any value.
Is another function to act as an energy reserve for the braking function?
I'm not familiar with the internals of a brushless ESC, so do not have a feel for exactly how the braking function works (I guess most of it would be firmware apart from the critical FETs).
On that point, does anyone have a reference to an article that describes the hardware and firmware functions of a modern brushless ESC?
Thanks in advance
cosmo1974 is offline
Old 08-03-2009 | 11:03 PM
  #448
Just some quick Q's for the SP guru's.......
Is there new software being developed which will have a "boost" style function of ramping up timing at full throttle as this is all the rage at the moment in the top line speedies?
What are the differences between the new line of SP mod motors and the older 2.0 series?
Cheers.
Dragonfire is offline
Old 08-04-2009 | 11:14 AM
  #449
cyanyde's Avatar
Cheers.
I second that "boost" or "turbo" mode query... tired of getting whipped on the straights in stock races.
cyanyde is offline
Old 08-04-2009 | 02:00 PM
  #450
Gee I don't know about that. I have heard lots of comments about x205x software you guys all run but I run much much older and find it faster. I believe its the 4th up from the bottom of the list. It has more top end than anything else I have tried and has a nice feel about it too.
