The Speed Passion Thread
#4052
Mine was HW so i sent both at the after-sales service of HW at China ShenZhen and i got them back after 12 days.Sorry.
#4053
and it's been 4day after last report from KG, that our Speed Passion Product already pass Repair Department.
and So will wait for next report.
#4054
Super Charge and Cirtix Motor
perhaps.
but HW might not able to answear my last question that i gave to ShawnPalmer
The last Question is How SuperCharge Software Work's ON Cirtix Slotless Motor.
and i know HW dont have Cirtix Slotless Motor. (for now)
maybe that's why the SP became the first and foremost.
#4055
Do you know how many times I have been censured about mentioning Hobbywing and Speedpassion in the same sentence!!!
Now everybody is getting away with it scot free !!!!
WTH
WTH
#4056
#4058
Hobbywing software....use on hobbywing speed control
Speed passion software....use on speed passion speed control.
You tell me where is the problem here......I think you should post that on your own hobbywing thread, you created one, and you should stick with that one.
On the other side note....us test driver has a full detail PDF explain each version what was changed and what was improved and what setup to use to start testing the software. Now...your source from CHINA (Hobbywing part) should send you a full detail listing of the different between 231 and 318...THEN, another full detail about the different between 318 and 324. NOW...they should send you another full detail about the different between 324 and 3XX version...
We do get these information from Speed Passion. How about your Hobbywing source? Ask them to forward you the info...as does the base line setup.
If you do use the speed passion version, you won't have to ask the question about should you use 318 or use 324...come on, if you do have it, keep it to yourself, or leave that at hobbywing.
#4059
You have concern or question regarding the hobbywing 422 software, there are multiple thread on Rctech that you can ask question there. For those SP customer that used the HW 422 software and if they do have concern and question regarding the SOFTWARE...they should go to the HW forum and ask question there...
Now...if you try to get a HOT TOPIC here in Speed Passion thread, you can save your time. Actually, someone started a Hobbywing 422 software thread that is pretty hot right now if you would like to piss off other ppl.
#4060
422 wtf
now that hw have brought out 422, which works on sp and is just as quick as gm and tekin, (i know i tried it on my sp gt2.0, and is very very good)(results on the other thread) when is the speed passion sw coming out?
is it gonna be the same but with a different number? is 422 wot the sp drivers have been testing for hw? dont know, dont care. 422 is here and the gaunlet is down..................
come on sp, bring one out that is better,if you can...................
#4061
No double standards here...
#4062
The official release date of the approved software should be very soon, we are trying to gethering all the decent setup with multiple motors turns, type of chassis and different type of track condition. The team need to actually go to the track and test it, instead of guessing it....
#4063
I can tell you this....SPEED PASSION version of 422 has different numbers on mulitple areas/options that are different then the Hobbywing version. And these numbers are typically HIGHER then the Hobbywing version. Thats all I can say.
#4064
#4065
You have to face the facts though that SP has been ripping everyone off with the prices of what is essentially a HW system .
But then again the SP labels may be very expensive
