"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors >
Old 04-09-2009, 08:12 PM
  #136
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Benn0
Here is my actual setup
Madzaspeed
Sorex 36R with CS Tire-Max Grip heated to 60°
No screw on the topdeck for steering
Front:
Blocks: C - C
Camper: 2°
0,5mm Antidive
0,5mm wheel spacer
5mm height
Damper: 400er tamiya oil
white springs Tamiya
3-hole plates
2nd hole from inside on damper bridge
Rear:
Blocks: XA - E
Camber: 2°
0,5mm Rollcenter
1mm wheel spacer
5,5mm height
blue springs Tamiya
3-hole plates
5th hole from inside on damper bridge
a lot of stuff but I hope you can help me
Felix
Your setup is very similar to what I used to run. Try the base asphalt setup that Jilles posted a few pages, back - you wont be disappointed!
CraigM is offline
Old 04-10-2009, 03:32 AM
  #137
The next time I will try the basic rubber Setup. I'm sure it works better than mine
Jilles,
do you always use a 2mm spacer for the front suspension arm? In the basic setup from the manual it's written with 1,5mm. Do 2mm work better or is it just better for modified ? (I'm running 9.5)
Is it correct that you raised the rollcenter by adding more spacers on the bulkheads?
thaaaanks
Felix
Benn0 is offline
Old 04-10-2009, 09:26 AM
  #138
jonest's Avatar
Jilles,
What traction compound u guys were using during:-
1) TITC 2009 (outdoor asphalt)
2) LRP TCM09 (indoor carpet)
And what's the best method to apply / wipe off?
And of coz the duration (mins before race / duration) and were tire warmer being used?
Thanks.
jonest is offline
Old 04-10-2009, 02:24 PM
  #139
JGH
Felix,
2mm or 1,5mm is a very small differents, you might try 2mm and then 1mm to feel the differents.
Jonest,
At the TITC we used Paragon Fx2
At the LRP masters we had to use as a control additive the LRP carpet 2 which works really good on the LRP tyre.
Normally on carpet we use either LRP carpet 2 or CS yellow.
For carpet I never use tyre warmer, apply the additive around 20min in the rear and 10min in front. If you still have too much steering I can advice to apply additive shorter time on the front.
FX2 at the TITC also without tyre warmer and for 5-10min.
Always wipe off the tyre so it's completely dry going on the track.
Jilles
JGH is offline
Old 04-10-2009, 03:00 PM
  #140
smoke81's Avatar
How much of the front tire do you dope?
smoke81 is offline
Old 04-10-2009, 03:35 PM
  #141
does any one now if this fits on a TRF415?
http://rcmarket.com.hk/product_info....oducts_id=3438
mikky32 is offline
Old 04-10-2009, 03:42 PM
  #142
94eg!'s Avatar
Trader Rating: 17 (100%+)
Of course not. The front pulley is in a different place on the 415 (center)...
94eg! is offline
Old 04-10-2009, 05:30 PM
  #143
ab1105's Avatar
Trader Rating: 20 (100%+)
Jilles:
Have you ever loaded your 416 bumper with weight before? I saw a setup in a Japanese magazine that Satoshi Maezumi did with some weight between the plastic ad foam bumper. Wondering the effects of this and if you have messed with it.
ab1105 is offline
Old 04-11-2009, 02:32 AM
  #144
TryHard's Avatar
Originally Posted by ab1105
Jilles:
I'll chime in a gain as well...
Given I'm running LiPo, thats where I have about 20g of weight stashed, helps to get the weight forward.
I also was originally runnig a Ti/Alu screw kit, but I switched out all the ti under chassis screws for the standard steel ones, as it get the weight nice and low, and also means you don't have to add extra weight around. It's not much, but it all helps to get the weight low
HiH
Ed
TryHard is offline
Old 04-11-2009, 04:37 AM
  #145
3.141592's Avatar
Originally Posted by JGH
3,1415926
I'm a little confused about your 1534 gr. As my 416 weight around 1400 gr. with titanium screws. When using JB inserts it's way under 1400 gr.
Yes Jilles, sorry for the confusion. it was 1434 grams on my 416WE
3.141592 is offline
Old 04-12-2009, 12:23 AM
  #146
ab1105's Avatar
HiH
Ed
I'm running 5 cell ni-mh cells. The weight under the bumper thing was for weight transfer purposes and perhaps more steering. Thats why i asked.
ab1105 is offline
Old 04-12-2009, 02:38 AM
  #147
Hi Jilles
Question about SP Motor. What timing do you use on carpet/asphalt track on 3.5 and 4.0 motors?
And what gearing you propose for 4.0T/5 cells on fast asphalt tracks?
Thank's
orzel24 is offline
Old 04-12-2009, 08:12 AM
  #148
adamge's Avatar
Ballasting an area of the chassis does _not_ affect weight transfer.
adamge is offline
Old 04-12-2009, 09:04 AM
  #149
Huh. Go to any stock car dirt track and watch them slide the weights up the roll cage as the track drys to do just that. As well ahead or behind the axle makes a difference in how weight transfer comes in.
Cammer is offline
Old 04-12-2009, 10:33 AM
  #150
adamge's Avatar
Well, since you brought up the technique of putting ballast at various heights on the chassis - which was never in play in this thread - I'll be more specific:
Where you put ballast on the lower chassis plate does _not_ affect weight transfer. It permanently affects weight distribution.
adamge is offline
