T.O.P. Racing "Photon" 1/10 EP Touring Car
#7022
ESC: Tekin RS
Battery: Trinity
Body: protoform speed 6
Radio: futaba 3pk
Charger: Thunder power 610-C
Traction:[/QUOTE] Jack the Gripper
#7024
I am having some issues with a lot of chatter and vibration coming from the front end of my car. Is there any way to fix this without buying the ECS shafts right away? I have Regionals this weekend and I would like to get this fixed. I believe this is really effecting my car and it is getting annoying.
#7025
http://www.amainhobbies.com/product_...n-Holder-Red-4
The next thing I would suggest is mugen joint grease. And don't be afraid to put a lot in there.
http://www.amainhobbies.com/product_...r-Joint-Grease
The only time i've ever had chatter problems was after borrowing a set of cvd's, and they weren't lubed
#7027
The first thing you should do is get the axle pin covers.
Thanks for your help Dustin and D. Locke. I do have the axle pin retainer and it did make a difference but not enough. Do any of you ever have any problems with these sticking to the axles? As far as the grease goes, I think I need to add quite a bit more than what I have using. I have just been barely putting any on there. Is there a point where there is just to much?
#7028
I have had a few that were a touch hard to get off, but none that have got stuck.
Really I don't think you can put to much in.. When you put them together it should squeeze most of the extra out. Then what ever extra left over will fling out as soon as you pull the trigger the first time.
#7029
My uPro is nowhere near notchy. Its smoother than the best ball diff i have ever built.
#7030
Which is why I bought two, it seems like a lot of people bought them, put in zero effort and gave up on them right away, but look at the Spec-R thread, or elsewhere, guys had major troubles with them, but some kept at it, even in the face of many rubbishing them, yet play out to recently and most say they are great now.
#7031
#7032
#7033
Chad, let me know if you want to switch cars for reginals this weekend hahaha... Dont for get if you run the 21.5 class you need to add a tank worth of weight!!!!
See you there! I made some changes to my car... It should be faster
#7034
