T.O.P. Racing "Photon" 1/10 EP Touring Car
#6812
What servo are you using Kling? A few of us have been running within a hole for the outside wing, and drilling an additional mounting hole. This works for the JR 8800S or Spektrum 6040 servo (along w/ a little dremel work on the servo case).
http://racerlog.com/wiki/T.O.P._Photon#Servo_Mounting
I can pull together some measurements tomorrow if people are interested...
#6813
Hey guys, just purchased a Photon. Do the diff's come pre assebled in the kit?
#6815
#6816
#6818
Het guys, selling my nice photon.
#6822
#6824
NEW PARTS
I just want to know - which of the new parts are worth getting the most - in other words which make the biggest improvements on a V1 car?
1. Chassis?
2. Steering?
3. shocks?
4. allow top links?
5. carbon fibre arms?
etc - etc - etc
do top do an upgrade kit?
1. Chassis?
2. Steering?
3. shocks?
4. allow top links?
etc - etc - etc
#6825
Shocks - The new ones are definitely better than the v.1 shocks
Optional 1.25mm CF camber link plates allow you to run longer links
The new top deck screws are better. Less likely to strip the heads (deeper 2mm hex) and the screw is .1 mm wider to fit the holes tighter.
CF Arms are lighter. I have yet to fully test their durability.
Alloy steering blocks. Last longer, unless you happen to bend one. I haven't yet. They are less prone to having the camber link ball studs pull the grub screw out of the hole. They're shiny
Alloy rear hub carriers. More durable. I never had a problem with the plastic ones, but others have. I just like them because they match the rest of the shiny bits on my car.
Alloy/CF bellcrank set is stronger and looks nice. The alloy radial Ackerman inserts are a must IMO.
Alloy axle pin retainers. Get them!
Serrated wheel nuts rock! They spin on and off way faster and they hold better.
Last edited by locked; 01-16-2011 at 08:57 PM. Reason: Replied quickly while at work. Omitted some items.
