T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 08-02-2010, 08:29 AM
  #5101
jdearhart's Avatar
Trader Rating: 15 (100%+)
Originally Posted by stiltskin
I always hit it the first time, every time.
Originally Posted by DaveW
Glad I'm not the only one with a dirty mind!
jdearhart is offline
Old 08-02-2010, 08:48 AM
  #5102
Registered User
Bunch of Pervs. lol
dannybcaitlyn is offline
Old 08-02-2010, 11:37 AM
  #5103
DaveW's Avatar
Knowing Tony, he typed it up like that on purpose too...
DaveW is offline
Old 08-02-2010, 12:07 PM
  #5104
stiltskin's Avatar
Trader Rating: 103 (100%+)
Say what?
stiltskin is offline
Old 08-02-2010, 03:20 PM
  #5105
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Those Gear Diff .... From NIP are they suppose to be tight?
They don't spin free or smooth like the ball diff.They felt like this is a notch or something inside .
what diff oil brands is everybody using ?
OVA is offline
Old 08-02-2010, 03:25 PM
  #5106
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
the 1st thing i did i took it apart cleaned out all of the original oils then I filled it with 10,000 OFNA diff fluid in the rear. After a few runs is smoother than my ball diff, the front gear diff i did the same but Im running 120,000 OFNA diff fluid.
Marcos.J is offline
Old 08-02-2010, 03:31 PM
  #5107
RC MARKET's Avatar
Mirco Pro Gear diff. base on Xceed 20K oil ,
you can find around 10k-50k to fit your style to control .
RC MARKET is offline
Old 08-02-2010, 04:04 PM
  #5108
OVA
OVA's Avatar
Thanks...
OVA is offline
Old 08-02-2010, 04:05 PM
  #5109
OVA
OVA's Avatar
OVA is offline
Old 08-02-2010, 05:45 PM
  #5110
PDX-Spike's Avatar
Note that the 10K to 50K oil suggestion from RC Market is cSt, not SAE.
PDX-Spike is offline
Old 08-02-2010, 05:51 PM
  #5111
OVA
OVA's Avatar
Thanks Roger...
I need mike P..set up from the last TZ race...please PM back....
OVA is offline
Old 08-02-2010, 07:08 PM
  #5112
defcone's Avatar
The gear diff screws which hold it together, are you not suppose to do them up tight? My gear diff binds when I do them up tight.
defcone is offline
Old 08-02-2010, 07:47 PM
  #5113
PDX-Spike's Avatar
You know what I'm going to say. I really like tight screws.
Old 08-02-2010, 07:54 PM
  #5114
stiltskin's Avatar
Did you take the internal gears apart? Make sure the shims are seated properly on the outdrive shaft.
Old 08-02-2010, 08:15 PM
  #5115
Trader Rating: 23 (100%+)
I found that it helped to orient the case the same way it came apart when changing oil. If the case halves are 180 deg out, they get a little notchy. I've now marked the cases for future reference. Anyone else find the same?
pcar951 is offline
