T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 07-02-2010, 06:15 AM
  #4771
Nova F1 Racer's Avatar
Originally Posted by FREAKAH
Cause.........maybe they don't read French...or whatever.
Originally Posted by Bishop
Nice site, but yes my French is very rusty, and technical articles don't translate well either, found that out trying to make sense of some German technical stuff years ago...
http://babelfish.yahoo.com/translate...e.htm&lp=fr_en
Engresh version...
Main page..
Nova F1 Racer is offline
Old 07-02-2010, 07:35 AM
  #4772
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by stiltskin
Not sure what kind of setup you're running. Foam/Rubber, spool/diff. I was never able to get the spool to work for me on carpet. Our track always starts out low then comes in throughout the day. I ran a front diff in my car and had great success with it. Only 3 cars were able to run 37 laps and I was the only one with 38. Turned very well and never felt unsettled. I was running the 2.5 lipo chassis as well on rubber tires.
what about out door racing .still using front diff as well?
OVA is offline
Old 07-02-2010, 10:12 AM
  #4773
Trader Rating: 23 (100%+)
speaking of diffs....any word on the photon gear diff yet? gotta be out soon right??
pcar951 is offline
Old 07-02-2010, 10:54 AM
  #4774
vabroom's Avatar
Eventually!! I'm holding up my next order for parts until the gear diff is out.
vabroom is offline
Old 07-02-2010, 11:28 AM
  #4775
me too....
pcar951 is offline
Old 07-02-2010, 12:31 PM
  #4776
RC MARKET's Avatar
i'm try monday !
RC MARKET is offline
Old 07-02-2010, 03:06 PM
  #4777
stiltskin's Avatar
Trader Rating: 103 (100%+)
No. Definitely a spool outside.
stiltskin is offline
Old 07-03-2010, 07:24 PM
  #4778
Where do we measure droop on the Photon? The loop on the bottom of rear uprights makes it hard to measure. I've seen setup sheets showing .5mm rear droop, that must be to the bottom of the loop...right? Is there a secret formula or something??
pcar951 is offline
Old 07-03-2010, 07:55 PM
  #4779
stiltskin's Avatar
Everyone will have their preference. If you're looking at someone else's setup sheet, you will have to know how THEY measure droop. If it's .5mm in the rear, I would assume they are using the bottom of the loop. I measure Uptravel from ride height myself. I only use the droop gage (under the loop FWIW) to verify that both sides are equal. On the front arms I use the area of the arm forward of the c-hub.
Old 07-03-2010, 10:35 PM
  #4780
Thanks for the help Tony.
pcar951 is offline
Old 07-04-2010, 08:58 AM
  #4781
Bishop's Avatar
Just an interesting build observation, looks like version 2 shocks still have the loose piston fit I read about earlier in this thread, so if your buying or building a photon even with the newer shocks, make sure to get some .3mm thick small diameter 3mm internal hole shims.
Oh and the spur pulley will need some tweaks as well, also shims, what comes with the kit won't give you a centered spur, it needs different shims to center it properly, not huge deal, but it would have been nice of TOP to throw in some shims so you can tweak these things without having to buy more bits.
Mind you it's not like TOP are alone in this, I really need to build up a better collection of shims myself, keep needing more and never have the right sizes...
Bishop is offline
Old 07-04-2010, 10:21 AM
  #4782
RC MARKET's Avatar
Ver. 2 Shock , so best choice at piston 1.0mm x3
Old 07-04-2010, 01:56 PM
  #4783
pinggoy's Avatar
Trader Rating: 24 (96%+)
quick question guys,,, is there any TOP drivers in 2010 ifmar??
pinggoy is offline
Old 07-04-2010, 02:17 PM
  #4784
darrenoakley's Avatar
Having real trouble finding replacement 10.5 ball cups. Can find the 14.5 and bigger but not the 10.5. Its the ones that go on the bottom of the shocks and on the sway bar adjuster. Anyone no if they are available as a pack or do you have to buy the complete sway bar kit.
darrenoakley is offline
Old 07-04-2010, 08:57 PM
  #4785
Bishop's Avatar
Yeah Top don't seem to sell them as a separate part, to get two you need to buy the plastic shock parts bag - TC-PMMS02, it's not that expensive, but it's what I had to buy when I broke my sway end link.
Bishop is offline
