T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 06-02-2010, 10:10 AM
  #4561
E.J. Evans's Avatar
Originally Posted by linger
EJ will probably kill me for this - but this is the new super narrow chassis TOP was caught experimenting with
Good job making the main Ling! That's a lot better out of you then I expected. LOL
E.J. Evans is offline
Old 06-02-2010, 10:25 AM
  #4562
Official's Avatar
Hi Guys,
Just wanted to share some experiment i did today.
Well i got a one-way front pulley in hand and was thinking i might as well try it.
So i pop it in. Well most folks will just pop it in the front. As my belts were already flipped due to the new chassis, i pop the one-way in the rear to give it a try. Guess what. I had a lot of Fun!!!. Imagine Front Solid Spool and rear one way. The Cornering Speed is Astounding. It just need to set the rear for more grip. Maybe this might be a new trend.
Maybe someone might want to experiment this layout a bit more.
Official is offline
Old 06-02-2010, 11:01 AM
  #4563
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by E.J. Evans
The Photon had a pretty good showing at the Reedy Race. I want to thank all the guys running a TOP car for all the hard work and support.
Eric Albano won 17.5. His car was good all weekend and drove excellent in the mains.
James Arluck ran the Photon and finished an impressive 2nd in 13.5. I think James held TQ through 3 rounds of qualifying.
Jesse Stark finished 3rd in open modified. He had some impressive runs, but just some bad luck in the mains.
The 2010 ROAR Nationals will be held at the same track (Norcal Hobbies). If you plan on coming we'll have a good starting setup.
I heard that the you ran rear gear diff @ Reedy?
Will TOP Racing will have those available for photon ?
Goingfast is offline
Old 06-02-2010, 12:35 PM
  #4564
RC MARKET's Avatar
mid of this month release !
RC MARKET is offline
Old 06-02-2010, 04:24 PM
  #4565
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by pmc
Hello
Shock Spring
PS-TR15550 Gamma Spring 393gf/mm, 22.0lb/in (2 pcs)
PS-TR15575 Gamma Spring 367gf/mm, 20.5lb/in (2 pcs)
PS-TR15600 Gamma Spring 344gf/mm, 19.2lb/in (2 pcs)
PS-TR15625 Gamma Spring 324gf/mm, 18.1lb/in (2 pcs)
PS-TR15650 Gamma Spring 306gf/mm, 17.1lb/in (2 pcs)
PS-TR15675 Gamma Spring 289gf/mm, 16.2lb/in (2 pcs)
The springs that come with the kit is the 344 in front and 306 in the rear.
Best regards:
Pedro Silva
Thanks bro
STLNLST is offline
Old 06-02-2010, 04:26 PM
  #4566
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Originally Posted by STLNLST
Can someone please post part numbers to the aspahlt springs used on the Photon? Thanks
Oh hell no, not you too? There goes the neighborhood...
JamesArluck is offline
Old 06-02-2010, 07:00 PM
  #4567
stiltskin's Avatar
Trader Rating: 103 (100%+)
Big congrats to all the TOP guys at the Reedy. You guys represented well.
stiltskin is offline
Old 06-02-2010, 07:01 PM
  #4568
Goingfast's Avatar
1+
Old 06-02-2010, 08:16 PM
  #4569
pakk's Avatar
Trader Rating: 80 (100%+)
Default While we are talking about springs....
Top Racing (Spring Rate engrave on the spring)
Gamma 393 gF/mm
Gamma 367 gF/mm
Gamma 344 gF/mm
Gamma 324 gF/mm
Gamma 306 gF/mm
Gamma 289 gF/mm
Alpha 626 gF/mm
Alpha 591 gF/mm
Alpha 560 gF/mm
Alpha 532 gF/mm
Alpha 507 gF/mm
Beta 347 gF/mm
Beta 325 gF/mm
Beta 306 gF/mm
Beta 294 gF/mm
Beta 274 gF/mm
*Gamma Spring is design for rubber asphalt racing
*Alpha & Beta spring is design for carpet and foam tire racing
How do these springs differ besides their weight?
For example on my rubber asphalt car, if I was running Gamma 289 gF/mm in the rear and thought they were too light but also thought Gamma 306 gF/mm were too heavy, could I run Beta 294 gF/mm? Or does it not work that way?
pakk is offline
Old 06-02-2010, 09:42 PM
  #4570
Mini-Mod's Avatar
Thanks. The TOP car really is a performer.
Thanks EJ for all the help.
Mini-Mod is offline
Old 06-02-2010, 09:48 PM
  #4571
STLNLST's Avatar
Not getting the car. Just the springs.
STLNLST is offline
Old 06-02-2010, 10:18 PM
  #4572
pakk's Avatar
That's where it starts. Then the shocks, sway bars, diff.... Just buy the kit. You'll end up saving money in the long run.
pakk is offline
Old 06-03-2010, 05:12 AM
  #4573
mazmo's Avatar
Default traction roll
Am getting traction roll on a indoor high grip asphalt track. Very 'sticky' kind of grip as they use traction additive on the track.
Have race there before with other chassis, never had traction roll.
Am using EJ's rubber set up, only change medium / high roll centres.
On Sorex 36 with C medium insert.
Tried harder springs and standing the shocks up by one position front & rear, didn't seem to help. Am now thinking I need to go with softer set up & more roll / droop.
Has anyone had same issue, would welcome suggestions.
mazmo is offline
Old 06-03-2010, 05:20 AM
  #4574
STLNLST's Avatar
I have no interest in buying the kit. Really just want springs.
STLNLST is offline
Old 06-03-2010, 06:29 AM
  #4575
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
I would suggest trying my setup I posted back in mid march. The higher you go on the roll center and the stiffer you make the back(Standing the rear shock up) the more your car is going to wanna flip.
Maybe shorten the links to middle hole if you arent already and go lower in the rear roll center to med low if you dont wanna lower your front RS.
L.Fairtrace is offline
