New Yokomo TC, the BD-5 >
Old 04-29-2010, 11:39 AM
  #1651
Default BD-302 VS BD-302LW
Hello is there any difference between this part BD-5 Center Bulkhead 302 and the new 302lw, I'm updating my bd-5 and I would like to know whether the bd-302 part performs the same function that the bd-302lw greetings
manchu is offline
Old 04-29-2010, 12:12 PM
  #1652
altreyx's Avatar
main difference is the motor screw position, so with the 302lw i don't think you can use the original upperdeck or the lipo one but you need to change also the upperdeck with the world version (BD-003W)
The screw position is now vertical so the bulkead is no more flat, so the world upperdeck is not passing over the bulkhead but inside.
If is not clear i hope this picture will explain better what i mean. Hoping this can help you.
altreyx is offline
Old 04-30-2010, 09:19 AM
  #1653
KoolRC's Avatar
Trader Rating: 75 (100%+)
ttt
KoolRC is offline
Old 04-30-2010, 09:44 AM
  #1654
defcone's Avatar
Trader Rating: 15 (100%+)
The new motor mount also allows you to fit more gearing as there is more horizontal motor movement.
defcone is offline
Old 04-30-2010, 10:05 AM
  #1655
fpart's Avatar
Trader Rating: 41 (100%+)
Any more news about the upgrade kit to make a BD-5 to a BD-5W??
It also looks like with the new motor mount that you don't need a special gear with holes!
fpart is offline
Old 04-30-2010, 11:29 AM
  #1656
defcone's Avatar
That too.
defcone is offline
Old 04-30-2010, 05:22 PM
  #1657
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Ive seen pictures of the upgrade kit already, im sure Elwynn will have it soon There ya go, a pick of one
The new motor mount makes the car sooooooo much easier to work on, and yes, no more spur gears with the holes
Antoni
Yokomo_Ant3 is offline
Old 04-30-2010, 06:44 PM
  #1658
Here is a copy of the BD5W blank setup sheet.
http://www.teamyokomo.com/jpn/downlo...blank_bd5w.pdf
Anyone want to turn it into a jpg file so we can edit it? I tried but i came out a bit blurred. Or does anyone know how to edit Adobe pdf files?
Thanks Antoni
Old 05-01-2010, 12:59 AM
  #1659
altreyx's Avatar
Thanks Antoni
Hello Antoni,
i'm working on it.. will see what i'm able to do.
For to turn it in Jpg is a job of 2 minutes (just tell me if you want it, i'll send it by Email) but i'm working for to have a PDF editable sheet with the new options.
Ciao,
Andrea
altreyx is offline
Old 05-01-2010, 02:41 AM
  #1660
Originally Posted by altreyx
Hello Antoni,
Ciao,
Andrea
That would be awesome Andrea, would love an editable PDF setup sheet Ill wait to see what you come up with.
Thanks,
Antoni
Old 05-01-2010, 05:04 AM
  #1661
Default shock absorbers BD-5W
can somebody desir the configuration of the shock absorbers of bd-5w if this
YS-8HD
YS7HG
BD-S2B
manchu is offline
Old 05-01-2010, 09:21 AM
  #1662
altreyx's Avatar
Arrow BD5W Setup Sheet Editable
let me know if you have issue using it, should work without problems.
Ciao
http://www.megaupload.com/?d=EKALJ25M
altreyx is offline
Old 05-01-2010, 02:15 PM
  #1663
altreyx's Avatar
Thanks to Arn0 for his upload, you can find here the Setup Sheet for a better download.
Regards,
Andrea
http://www.petitrc.com/reglages/yoko...YokomoBD5.html
direct link: http://www.petitrc.com/reglages/yoko...SetupSheet.pdf
altreyx is offline
Old 05-01-2010, 04:14 PM
  #1664
SammyZ's Avatar
Trader Rating: 138 (100%+)
besides, chassis, top deck, and motor mount, what changes were made to the World Spec kit? also whats different about the top deck?
SammyZ is offline
Old 05-01-2010, 05:51 PM
  #1665
KoolRC's Avatar
Thanks,
Antoni
just ran my bd5w today awsome ride just one issue the c hubs are fragile do they make a stronger one?
KoolRC is offline
