You can set the cut off at 0.1v per cell, which is very close to 0v.But I doubt you want to dead short a NiMH cells, it is suposed to be bad for NiMH.
caveman are you refering to the rayspeed or the integy? I have tried some dead shorted packs and it works great at the expense of run time. You should dead short for at least a few days to get any effect and the IR's keep incredibly low
I refer to rayspeed discharger,you can chose either 0.9v or 0.1v cutoff at conditioning mode(1amp discharge). It seems to me everyone has his own way to threat his packs, someone told me to put the packs into freezer for a week and helps to lower the internal resistance. But thanks for the tips, I may try it.
get an equalising tray ooj.. they cost.. but they ensure all cells are equal. get one with a 0 volt cut off, as 0.1 is no good.
thanks for the advice carbon
I think I will get the octane 2. Is that the one you use or recommend? |
that it is.. i use it all the time .. and giv it the big thumbs up
rayspeed discharger 4 cell???
How do you discharge 4 cell packs on the rayspeed discharge tray.....??? Where do you place the cells? Thanks
ttt
:D
Re: Integy Octane 2 VS Rayspeed EXceed
Originally posted by FUK_WRX Hello guys just wondering which you think is better, the Octane 2 or the new Rayspeed Exceed discharger ?? hi luie... Pro Rayspeed - .9 cutoff - looks great Con - if you're planning to deadshort, this wont work. - lower discharger rate than the octane 2 Pro - Octane - high discharge rate - can be used for dead shorting Con - i personally prefer the .9 cutoff, 0 volt cutoff is a con to me - not available here. |
Re: rayspeed discharger 4 cell???
Originally posted by picco007 How do you discharge 4 cell packs on the rayspeed discharge tray.....??? Where do you place the cells? Thanks |
Discharge rate isn't important with nimh's since they have (in theory) no memory. The only advantage to higher discharge rate is it's quicker. I have a real time 2.5 and it works fine but you do have to watch it and unscrew contacts when the bulb goes out. The Rayspeed would be the better one for nimh's in my opinion since it can't run the cells down too low
Ooj-To answer your question your charger will discharge at 20 amps to take the pack down to 5.4v/p or .9v/c.
A tray simply takes each cell individually and equilizes them to be even.Now in MOST cases NIMH dont have memory but it's been proven GP3300's do. GP3300's actually LIKE to be deadshorted.They will gain voltage,lower internal resistance at the cost of 12-25 seconds runtime.This will NEVER hurt you unless running mod sedan,oval. In all offroad,spec touring,stock touring,or most 1/12th scale it will not affect you in dumping being runtime is crazy now anyway. The Octane 2 by Integy or the Trinity 2.0 or 2.5 are the ONLY 3 trays safe for Deadshorting being the bring the cell down to 0volts. The Rayspeed,other integy trays,Promatch tray and others all cutoff at something short of 0 safely. When using the Octane 2 or Trinity 2-2.5 you dont have to worry when the lights go out due to deadshorting.The resistor will keep them from reversing. I charge at 6.0amps at a .05 cutoff on my 3300's.If im charging outside I lower the cutoff to .04 or .03 depending on outside temp being 95 or above.Being it's already warm outside it simply cuts the cell off at a safer level.I run the pack.Discharge at 20-30 amps depending the type of racing.The discharger I use either it be a charger with discharging features,Lights with a cutoff or a Integy Reactor all cutoff at .9 per cell.Then I put them on a Octane 2 tray and bring them to 0.I leave them on about 2-3 minutes after the lights go out and solder a wire from positive to negative.Take off the tray and store till the next weekend or every other.The packs have been great and been using them on a regular basis since March.Almost 9 months and strong as ever. SMC's driver at the october race won with 7 month old packs.Very UNusual for a team driver racing onroad to be using packs with that much use on them.He deadshorts and loves it.As a mainly offroad driver TRUST the Onroad oval guys.They KNOW how to care for batteries. Hope this helps |
Re: Re: rayspeed discharger 4 cell???
Thanks Demetris, that's what I was looking for. Perfect! Ronnie |
