Old 11-08-2009, 07:35 PM   #511
Originally Posted by WIITA View Post
I have a question for team tekin. I have a couple tekin rs speed controls and never seen this:
Bring my car to the track right before the main and turn the radio on then the esc, I had steering but no throttle. 3 lights were blinking one the esc. Tried to reset it and nothing. Same 3 lights keept blinking. Had the track owner come over and did a factory reset and it worked. I was running v200 all day and it worked great. Then changed a couple settings and this happened. I think when the reset was done it also reset all my settings and it was very slow and might have been set to the original version also. Any help with this would b wonderful. Thanks a lot.
The three lights will show up if your neutral setting is off. Either the radio is drifting or you're setting coast or drag brake on the radio with the neutral point.
Fred_B is offline   Reply With Quote
Old 11-08-2009, 09:17 PM   #512
theisgroup's Avatar
Originally Posted by DHMOTORSPORTS View Post
Any of you ever had the motor act like it was on a rev limiter? When you go full throttle it spools up and then starts cutting out so to speak.. I am useing a rec pack not a booster..Thanks
this happens if you over time the motor also.
I had a similar problem in vegas. Randy and I found a wierd thing. I was running a usb hub off my laptop and then the hotwire off the hub. I am not sure if my total length of the usb was too long, but I would set the speedo with hotwire and then I had no throttle. even after calibration with the radio. I removed the usb hub and plugged the hotwire and usb cable off the laptop and never had this happen again.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 11-08-2009, 11:03 PM   #513
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Quick question regarding the RS with either booster or rx pack.
When fully installed, does it matter which switch is turned on first? Battery to ESC or Booster to RX?
BTW assume FW200
rinkrat99 is offline   Reply With Quote
Old 11-09-2009, 07:07 AM   #514
WIITA's Avatar
Trader Rating: 42 (100%+)
Great, thanks a lot. I have a m11, any idea what setting I should look under with this radio. Again, thanks a lot!
WIITA is offline   Reply With Quote
Old 11-09-2009, 09:59 AM   #515
fire929's Avatar
Default Livewire
Is the live wire system a must for setting voltage cutoff for 1s lipo's
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 11-09-2009, 10:02 AM   #516
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
At the current time yes, you must have the Hotwire to select the 1s setting.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-09-2009, 10:14 AM   #517
fire929's Avatar
Default thank you
So you're using a laptop to program?
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 11-09-2009, 06:17 PM   #518
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
easyest thing to do with a tekin set up on 1s is eather a novak smart boost or a 2s reciver pack
TRXRACER99 is offline   Reply With Quote
Old 11-10-2009, 05:17 AM   #519
I apologise if this has been asked before!
When setting the Turbo delay, at what point does the "clock start ticking?
Say it is at 0.5 seconds, is that 0.5 seconds after you hit full throttle or 0.5 seconds after the full boost has been applied?
Also does the amount of time it takes for the boost to be applied differ depending on the value selected would 15degs of boost be applied in half the time of 30?
thanks
exint2 is offline   Reply With Quote
Old 11-10-2009, 07:32 AM   #520
thanks
it starts ticking as soon as you hold full throttle, the idea is to get upto speed using the timing boost then the turbo kicks in, if turbo kicks in before you will have that much timing on the motor it will end up being slower rather than fast and just heat the motor up.
jas1 is offline   Reply With Quote
Old 11-10-2009, 06:39 PM   #521
so is the turbo function additional degrees of timing or a percentage of advance
losidirt08 is offline   Reply With Quote
Old 11-10-2009, 06:57 PM   #522
Send a message via Skype™ to slotracer577
Adds additional degrees of timing after the delay, but it is a ramp up of that amount, so it doesnt hit all at once. you can see it when you free run the car.
Team Epic
slotracer577 is offline   Reply With Quote
Old 11-10-2009, 07:55 PM   #523
so if you have 20 degrees on the motor and 10 degrees in boost, what do u set the turbo at
Old 11-10-2009, 08:34 PM   #524
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Anyone know what the specs are on the TQ booster? I'm curious as to the output voltage and current capacity of the TQ booster.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-11-2009, 04:03 AM   #525
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
I'm not sure, but I think it's 5V. Two weekends ago, I was using an RX pack. Last weekend I ran a TQ booster. Both seem to function about the same, although I guess the steering would be a bit better using the RX pack. I really did not notice a difference.
I am curious if weight is a factor at all. Adding weight should reduce steering rate, right? So comparing the 2s lipo pack w/ 6v regulator versus to a tq booster at 5V, the effective steering rate may actually be about the same given the reduced weight of the booster. Just a guess, but I really don't think it matters in my application (1/12 pan) where I can get away with a $30 servo.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
