lrp spx stock spec
#572
What other speedo do you know that uses amp draw as an input? And how did you know about it?
#573
Ran my SPX with a Trinity Duo 17.5 on friday night and I'm VERY happy with it.
I'm new to stock,but managed to TQ first night with it in my XRAY T2R pro.
It had so much rip out of the turns,I was able to corner very aggressively .
Top speed was similar to the other cars. My roll-out is quite low and motor temp was ridiculously low too.
This week I can bump it up one tooth and see whether the punch drops.
I'm using #8 punch. Zero motor timing. No drag brake.
I also don't use manual brakes either.
Small indoor surfaced concrete on sorex rubber.
Heat sink on esc too.
#574
Double post
#575
SPX Speedy
Hi Guys,
Got my new SPX Speedy the other day, put it in the car the other night,set to profile 8, no drag brake, along with a trinity Pulse advanced at 12 degrees, also had 5000 lipo.
Did a coupl of laps up the street and back, wow fast!
Went to the track this morning, cool morning, excited about the new speed, went around 2 laps and thought, that seems slow. Went around again, car completely stopped. Got car back to the pits, and the speedy had blown up. ????
Brand new, 2 laps and it blew up.
WHAT THE HELL HAPPENED! DO YOU HINK THIS WILL BE COVERED BY WARRANTY.
Regards
Brad
Regards
Brad
#576
Hi Guys,
Regards
Brad
Regards
Brad
Make sure you didnt get the abc wires mixed up. Happened to me in my TC spec and speedo smoked. Would come on and work but barely moved the motor. No, wasnt covered.
#577
mate
try profile 7 and 6.29 ratio with the LRP 10.5 lipo . shhhhh dont tell anyone
Mark
#578
They should cover it. After you send it back, give them a call. They are more than happy to talk with you.
Hope all works out
Chris
#579
Hi Guys,
Regards
Brad
Regards
Brad
#580
i never touch the timing on my motors
i did once and the temps rocketed !!!!!
the motor was never as quick again
i am out this afternoon at the track again , switched from 4.0 the 6.2 to try but i think it will be slower
#581
i was just trying to explain how this speedo can do what it does & why its so different. about the problem he's having, im not sure but it does look like there might be a problem with his car.(check the sensor wire,speedo,bearings,etc.) whatever it is that doesn't sound normal.
I would really appreciate if you could elaborate a comparison between the two approaches to esc manufacturing which seem to exist on the market at the moment.
#583
Hi Guys,
Did a couple of laps up the street and back, wow fast!
Regards
Brad
Regards
Brad
#584
GEAR DOWN
I actually set it up to the same gearing as my mates car, who happens to run the same car, speedy and motor. He has had no problems at all, i would have thought the motor would have blown up before the speedy would have had problems.
I think there was a problem with the speedy, the car did two laps no more and then stoped.
