Tamiya TRF415
Originally Posted by PRO 2 RACER
Front one way is OK.
Rear arms OK
It spins as I first turn into the corner.
Rear arms OK
loose
Note sure about the droop I am at work and will have to check when I get home.
Originally Posted by stuey
iv'e just switched from a yokomo bd to the tamiya 415 used it for the first time tonight i cant belive how much rear traction the car has over the last year i've struggled to get a balance with the bd indoors but the tamiya is pretty good can't wait to get it outside.
hey edd hurry up and get back down south ill show you how you get a one way hooked up on carpet
stu rand
stu rand
And there was you telling me a Diff was the answer before....
Later
Ed
Ran my refine 2 for the first time at my local club (very very tight low grip carpet with no additive and rubber tyres) and it was dialed. Roll bars were off, diff in the front and centre direct pulley with .5mm shims under every block (i added another .5mm shim under the rear front block) with a Ride Honda Accord (A type with Flap RW wing). I could easily keep up with the 19T cars (i was running a 27T on about 7.8) which were doing about 9-10 second laps
Charles
Charles
We run on an indoor indoor cricket pitch astro turf type stuff.
very low grip also and no additive allowed.
1/12 is fun there
1/12 is fun there
Look what i have just ordered:
TECH Racing,5800YEN,TTA180 TA05 HIGH GEAR DRIVE UNIT(18T CENTER PULLY )
Thanks right.
Thanks right.
Just found a bent aluminium turnbuckle , best get on and order some titanium ones i think
Charles
Charles
Bent thats strange
They normally just snap
Either way it is kind of annoying
Charles
Charles
I am very confused...
Do the TA05 center pulleys (51213) 16t plastic pulleys fit on a stock 415??
Where do u bolt it on? there are no like set screws.
Alrigh-I solved my spinning out problem. It was a poorly glued tire!!
But unless I drive my 415ms like Miss Daisy-I over heat the rears in two hard driven laps and I am done.
Do rears over heat more from chassis set-up or insert? For sure my cars got mad steering so I really dont need to drive it that hard-its just in my foam tire nature.
Ray
Ray
If your using tyre warmers i would suggest not using them or turning them down. It could be that you have to much steering which is causing the rear tyres to slide which would heat them up to quickly (this is a possibility), or your tyres are of the wrong compound, for eg if your using CS-22s try CS-27s.
Charles
Charles
Thanks Charles. No tire warmers, but YES-my rears do slide and my cars very loose if over driven. Just looking for a set-up thats got steering, but isnt as loose. I might just be okay with going from saucing 1/2 front to 1/8" front. TIres are Tamiya type A with med firm thin inserts from Yokomo (TCS race!!). he track is med t hig bite with a black grooev as well.
Ray
Ray
I'm having problems with the Low Friction White belts - I keep loosing teeth from them. I must have used 9 or so in a year. I've tried running them loose, normal and tight with no difference. I only run 19t on carpet, but I have a very harsh throttle style.
Has anyone found a decent alternative to the Tamiya item?
Cheers.
Cheers.
Cheers.
Cheers.
