Like Tree3Likes
Tamiya TRF415
Old 01-23-2006, 03:55 AM
  #12436
Jack2's Avatar
Originally Posted by pookat
Did nobody notice the page number?
.....LOL......
Jack2 is offline
Old 01-23-2006, 04:20 AM
  #12437
TryHard's Avatar
woot woot
TryHard is offline
Old 01-23-2006, 05:32 AM
  #12438
sohlman's Avatar
Trader Rating: 92 (100%+)
Originally Posted by scoyle
I saw this a while back in this post and was wondering where it came from - is it designed to be a battery strap???
See attachment...
Looks like a battery strap from a CRC 1/12 scale car.
sohlman is offline
Old 01-23-2006, 05:42 AM
  #12439
Has anyone else tried this sort of battery strap?
scoyle is offline
Old 01-23-2006, 07:21 AM
  #12440
Carl Giordano's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Casey
anyone know the spring rate in pounds of all the Tamiya Onroad springs,
blue, red, white, yellow, grey, purple, ect.......
Casey, check Tryhard's website. he has a spring chart with all the sping ratings.
Carl Giordano is offline
Old 01-23-2006, 01:12 PM
  #12441
Registered User
xrcbuggy's Avatar
Need some help with this part please, Is the hole open on both side?
http://www2.towerhobbies.com/cgi-bin...0&I=LXETK6&P=K
xrcbuggy is offline
Old 01-23-2006, 01:15 PM
  #12442
Trader Rating: 18 (100%+)
Just woundering how can I get more corner speed with my ms ?
Roberto Falcon is offline
Old 01-23-2006, 01:16 PM
  #12443
huskerfreak's Avatar
On the blue aluminum I know that they are so I would think that these would be the same. But I don't know wh you would want that as if the screw is too long and goes through than the ball nut would not work properly with the ball cup.
huskerfreak is offline
Old 01-23-2006, 01:17 PM
  #12444
Racing4Evo's Avatar
YES
Racing4Evo is offline
Old 01-23-2006, 01:19 PM
  #12445
I had this problem this last weekend running a foam carpet setup. What I did was took rear toe out of the car with the pivot blocks and change the roll center in the rear with shimming the rear pivot blocks help out quite a bit.
Old 01-23-2006, 01:22 PM
  #12446
Registered User
xrcbuggy's Avatar
A nut & washer from the other side prevent the ball link ( I do not use ball nut) to pop-off during crash.
xrcbuggy is offline
Old 01-23-2006, 01:27 PM
  #12447
That makes sense. That sounds like a good idea. If that is what you were looking for have you thought of using the Xray turnbuckle ends. That would be perfect for what you are trying to do.
Old 01-23-2006, 07:23 PM
  #12448
Hey do guys have this problem with the ms ... my car steering knuckles bearings wallble .. what can I do to take that out!?
Old 01-23-2006, 08:03 PM
  #12449
m8commando's Avatar
I am almost finished with my masterpiece MSX, I will post picture in a couple more days.
Keep em spinning fellas!
m8commando is offline
Old 01-23-2006, 08:05 PM
  #12450
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default tamiya 3 hole pistons
Anybody know who has these in stock? Tamiya 3 hole piston part number 53573
Speedtech is out of stock and towerhobbies does not carry them.
Jamie
J.Gonzalez is offline
